E-Lockers
Seattle, WA
I am thinking about swapping a set of elocked '94 axles under a '91 fj80. I have heard about people wiring the axles so engage and disengage immediately. I would put toggle switchs in the cabin. Has anyone heard of this or do they know how to do this....it sounds easy enough, but wiring has never been my fortay.
I'm not sure what you mean about "immediately", the OEM wiring doesn't really have a delay to it. It mostly comes down to do you want to home-brew your own wiring and switch setup like I did (see linked thread), or just go to Toyota and buy the OEM parts ($$$).
if you want instant lock up in all situations then you need air lockers.
e-lockers are awesome but sometimes due to the location of the vehicle they will not engage instantly.
The 'delay' is the parameters that must be met for the lockers to engage, i.e; transfer in 4 low, CDL locked, ABS disengaged, rear locker first, then front. Without the factory relay system, you could engage any locker at any time.
-Spike
Additionally, the truck must be driven in such a way as to create a differential in RPM between the teeth of the dog collar on the axle and the teeth of the dog collar on the diff. This allows the teeth to mesh, i.e. lock.
The real reason the REAR e-locker takes so long to engage is the size of the teeth on the lock sleeve (like mentioned above). Bypassing the locker ECU and going with 12V directly to the motor works, but doesn't really make them engage any quicker (and IMO is just asking to over-run the actuator and bork it up). Have a look at the size of the teeth for the rear:
-Ferg-
