Hi,
Help me out. I read these two threads and was debating whether to start a new thread or post there because I think it is similar, if not the same issue:
Pinion Bearing wobble
Pinion Gear slop?
I had a shop install 4.88 gears and ARB’s shortly after I did my lift (75mm slinky) and there was some vibration just at the point between acceleration and coasting which I assumed meant that I needed a dc driveshaft. I started by checking and replacing a ujoint just in case, but no luck. Today I took the front driveshaft off and drove with the cdl on, no problem, hence confirming my suspicion about the dc driveshaft. However, while putting the driveshaft back on, I noticed the front pinion can move up and down ~ 1/2”, which can’t be good.
Did the vibration from the driveshaft cause this, or did the lose pinion cause the vibration? Either way, I assume this is bad and I need to take the third member out and do something?
Can I run without a front drive shaft and the cdl on for a few days iris that a bad idea?
Thank you in advance for any guidance.
Pinion Gear slop?
