Dual USB Audio & Power Dash Plug
Hanford, Ca
Website
instagram.com
These are all over the place on Amazon. The problem is they are for newer Toyota models. Has anyone ever found one that will fit in the 93-97 switch slots? @bhicks, do you think this will fit in your bezel?
I have been told the blue sea usb chargers fit my bezel but I have not personally test fit myself. The price tag was terrible so I never bought one. I have never tried the amazon one. I can give that one a try and let you guys know.
It wouldn’t be in your dash, but here’s the solution I came up with. In all there’s 2 USBs, an aux input and an hdmi input (all wired to the head unit). I’m generally annoyed by wires & cables crisscrossing the dash so this keeps everything tidy down by my hip in an otherwise unused space. Took about 20min to cut & install. Two pieces of advice: get the 6ft version of each...3ft is barely enough; and be sure to cut in an area where nothing behind will be blocking the routed cables.
USB Flush Mount Cable – Rerii 1 Meter 3ft Dual USB Extension Flush, Dash, Panel Mount Cable, for Car, Boat, Motorcycle and More https://www.amazon.com/dp/B00XJDP12W/?tag=ihco-20
HDMI Panel Flush Mount - Rerii 2 Meter 6ft 3.5mm & HDMI Extension USB Mount, Dash Mount, Flush Mount, Panel Mount Cable, For Car, Boat, Motorcycle https://www.amazon.com/dp/B01FLZN0K0/?tag=ihco-20
It's already in my cart. I need to order your cellphone holding contraption. I'm sure with your bezel and some finesse i can make it work.
They fit like a glove with a touch of trimming (trim the bluesea not the cruiser), the slot corners are more rounded and the blue sea corners are more square. I have 2 in my truck and they are great!
PLEASE post pics of the 12volt charger installed in my bezel if you decide to go this route. Maybe PM me the pics as well? I would love to see how it looks.
Will do. Should be here Friday, I won't get to it until Sunday.
I finally got around to doing this. I ended up using the smaller type plug. The one posted earlier wasn’t the right size. This smaller one wasn’t plug and play either. I ended up using a blank from the dash and I cut/filed a square hold onto it large enough to fit. I then had to glue the plug to the blank. The blanks don’t hold well in Bhicks’ dash bezel. They have weak tabs and the backspacing is off. I ended up just gluing it all together. It looks nice and I’ll be getting the phone mount attachment soon for the second hole in the bezel. Only got 2 finished pics. Didn’t get any of the work.
Now to get it wired and installed in the cruiser.
I got around to ordering the phone mount from BHicks. Not wanting to mess up the order he reached out to me to make sure I had the right bezel. Come to find out I was running 1.0 and he upgraded me to the 2.0ish version for a very unfair to him price. Brad’s customer service was real time and I was the one lagging in response. I installed it today and it looks great. Added bonus, the switch blank that I used is more snug in the new style bezel and I likely won’t need to glue it in. This combo is a nice creature comfort addition to the rig. Also, the placement of the phone in the bezel allowed for the facial recognition on the iPhone X.
