dual stabilizers. Anyone Doing this
sittin on the couch in UT
i just ripped of the old original stabilizer (pain in the A--) i put one from axle to tie rod and i was curious to see if anybody has done both and what were the end results. it did help a ton with wonder to and fro. :cool:
That shouldn't have much to do with the wandering.
You should really try and figure out why your truck wanders all over the road, opposed to installing something to cover the problem temporarily.
thanks for the input, but still doesnt answer the question? anyone
Poser said:
Where is the forest?
Mmmm. Not sure. I saw some trees over there tho.
On my other '73 with scout PS, 350, and 33s, I didn't run one. Never had a wandering problem. If you've got a problem with 33s, you might want to look at the rest of your steering/front suspension bushings.
okay i got the whole wondering not the stabilizer problem thenks for your concern, all im asking is for opinions on stabilizers? thanks
either you got an opinion or you dont :cheers:
No idea, I just realized the other night that there is a factory stabilizer mount. My stabilizer is missing. I dont seem to have any problems with steering.
Sorry I am no help to your original question.
Yes it's been done before. I had this on my old setup with worn out sprign bushings, TRE's and center arm... It works.
However, running dual stabilizers is only a band aid fix for the gushing wound that is nasty steering wantder.
First thing, if your truck is wandering all over the road the first thing I woudl check is play in the center arm (if you still have one).
-Excessive play in the cneter arm will cause steering wander
Next make sure that your tie rod ends are all in good working order (ie not worn out).
-worn out tie rod ends will cause steerign wander
next, check the bushings in your springs.
-Worn bushings cause the springs to move in ways they aren't supposed to, and will cause steering wander.
For what it's worth, I replaced all of those items with new OEM replacmeents, and I no longer need to have the steering stabilizer installed. I haven't run one since.
i think the general idea is that if one stabalizer isint working than somthing is wrong with your setup... I run no stabalizer at all,, SOA, SR, 37" MTR's no wander or feedback thru the Saginaw Power steering running new TRE and HYsteer.. My caster is set at about 3 Degrees..
Hope this helps.. ( i think only ford Show trucks need the Dual, Triple Stabalizers)
I ran one stablizer for many years to mask the death wobble that every other fix failed to solve...worked perfectly, and was cheap. Funny, but FJ40's came STOCK with one stablizer....Toyota must have had factory issues they never solved too.....
IMO, duals are completely unnecessary.
