7" is the boat standard, sorry i was wrong!
I have been using this set up. With this you have two main fuses right at the battery and you can pull direct power for starter and winch right off the main pole.
The picture that keeps floating around of melted winch wires is mine!! I hate to admit that.
If i would of had a fuse on the winch wires, the situation would of been different and i would not of melted my winch or had a chance to burn down my truck. It came from having the positive wire rub ever so slightly on a battery tie down. After a few years of this rubbing it finally rubbed through the wire insulation and exposed the inside to metal on metal.
A fuse would of popped or a breaker would of popped to stop the damage, but i didn't have one. Now, regarding the amperage of the fuse... that's above my pay grade right now.
If I simply added the small fuse block on my house battery and kept the 80A inline it would be fine? I don't really want to run another 6AWG to the back.
If so - stick with 80A at the battery to match the 80A 21" down line?
What gauge wire is feeding the fuse box? Remember, size your fuses to protect the wire. If you're running a small wire off of a 80A fuse, the small wire will melt before the fuse pops. Not what you want.
6 AWG. 18 feet back to rear breaker circuit box. 21" from battery to current anl fuse.
Edit: Said another way:
I have a 6 AWG from the house battery to the firewall of the truck. There I have a 80A Blue Sea fuse on the firewall. That fuse is 21" from the house battery. Then I run the 6 AWG back another 16 feet through an Anderson PowerPole connection and to the Circuit Breaker, where I distribute to the stuff in the rear.
Yes, you'll be fine.
Reference I'm using to make that statement:
12 Volt Wiring Tech: Gauge to Amps | Offroaders.com
I like a slightly more conservative wire gauge chart, and BlueSea has their ducks in a row:
Part 1: Choosing the Correct Wire Size for a DC Circuit - Blue Sea Systems
@weejub - Sounds like you're good.![]()
If you have the router out anyway, why not route recesses for the batteries instead of planing the board? Meh, either way accomplishes the same task unless you'd prefer to keep some areas full 1.5" thickness for some reason.
- Going to try to plane down my 1.5" structural base board.
- Regardless, I am going to route the edges and clean up the top cutting-board hold down to let the wires come down a bit on the terminals. This will also look better/cleaner.
Seems everyone is referencing the Positive. Don't forget your grounds. IMO from my experience, the grounds can cause more issue's than the positive cables.
