DS door handles
german village | OH
Driver's door handle just cracked... looks like I could do a repair with carbon fiber/resin (it's what I have/know).
Can anyone confirm whether the front and rear driver side door handles are interchangeable?
Would like to have a functional handle while the repair cures..
Thanks.
Wc
There is definitely not a lock on the rear handle. Not sure if interchange is the best solution.
Inside or outside handles? I have some inside ones if you need one.
I just assumed outside. Those are the ones that get damaged the most but you are right, Sam. The OP didn't specify interior or exterior.
I just picked up a junkyard replacement (exterior) and got it sprayed by a local auto body joint.
all of them are different parts because of the locks. i have patched them in the past depending on where it splits. there is an ok one on ebay if you want a quick fix.
Exterior handle.
I wanted to swap out front and rear temporarily, figured I could lock from inside if the handle was otherwise compatible.
I'll just have to work on it over the weekend.
Full cure time on the resin is 12h, didn't want to rush the finish work...
