Yeah. the light comes on in the inst panel, along with the ABS light.1st, is the CDL light working on the dash? Just want to make sure you're seeing a change there and not assuming locked/unlocked based on switch position.
I had the stock shaft in when I bought the truck. I blindly put the double in from Slee after PO stated that is what it needed. It make the slightest difference in sound.2nd, we've seen this only 1 shaft thing before. IMO it's in the front and either the drive shaft or how the truck was corrected for caster. Something is not allowing the shafts to work harmoniously. Did you have a stock shaft in there? If so how did it run and how did it compare to the dc shaft?
Any other settings as far as xfer/tranny positions? Didn't budge in parkCan you take the either the front output and or rear output (while you have the driveshaft off) of the transfer case and turn it in opposite directions with the CDL unlocked? You should be able to but it will be stiff. You might need two people to try.
And you did mention that the vibration is there with both shafts in with CDL locker or unlocked?
I Put the transmission in netural. And was able to rotate it with the cdl unlocked.I had the stock shaft in when I bought the truck. I blindly put the double in from Slee after PO stated that is what it needed. It make the slightest difference in sound.
from what you describe as a vib on decel with a stock shaft is normal for that shaft and your setup. A dc shaft should have fixed that. I'd try and find a known good front dc shaft to swap in there.
Do you think he could try to use spacers and the old non/dc shaft?
Or pull out the caster bushings and use the non/dc shaft?
Just thinking of some cheaper options to start with if he doesn't have a spare DC shaft to use.
I have a front dc. And i have the double cardon DC. Neither made any difference. Don't think it might be the rear, since the pinion seal is leaking?
well, the pinion seal can basically leak at anytime...vibrations may or may not have caused that. I would get that fixed quick tho.
If it were me...I'd try those spacers up front with both d-shafts. Maybe that 1" will get you into an acceptable range. It's a cheap way to find out if something works...$30.00 and some time.
Mr. Gasket Spacers, you can find them anywhere
Coil Spring Spacer - Mr. Gasket
FJBen;3060859 Or like Landtank said said:FWIW, it is or was, a brand new DC DS from Slee. Has maybe 1000 miles on it.
the plot thickens
you have a spacer up front.
yes, you are at a 4" lift now basically.
With the Slee 4" kit, he runs the caster plates and DC shaft...seems to work good with everyone.
I'm guessing that with the Drop caster brackets and the bushings...you are just in a weird spot/angle. I would vote for finding some stock arms to test out. Anyone near you that you could swap those arms on for a few minutes? There are pretty easy to swap out.
It still is possible the DC shaft up front is causing issues and/or is bad....only one way to check thattry another/swap/etc
)Hmm.. I do have slees caster plate kit that i never installed. Maybe put those on instead of swapping? But i also have those manfree drop brackets for the front control arms.. grrr(thats the same sound the truck makes)
If they were bolted on, it would make things A TON easier. At your lift height, you should be running either the plates, OR the drop brackets...even though you have good caster, you are in a strange spot...OR the d-shaft is bad.
