Drivetrain vibe
Reno, NV
Trying to fix an issue with a vibration on the front driveline. At about 55-65 mph under decel their is a noticeable vibration. I have a 4-5 inch lift with caster correction bushings. Just had the alignment checked and the front is at 2.9 degrees within spec. I've also replaced the front driveshaft with a double cardian drive shaft from slee. I haven't tried rotating the driveshaft 90 degrees to change the phase. Any other ideas? I was under the impression that the slee driveshaft comes balanced.
Dan
Our shafts are balanced when made. The phasing is not the same as a factory shaft due to the double cardan head assembly. I do not see how you can have 4-5" of lift with 2.9 degrees caster if you are just using the OME bushings. Also, are you sure it is the front? What correction for rear pinion angle do you have in the rear? Do you have a printout of the alignment specs?
Here is what i have from Firestone
Front left caster 2.9 degrees
Front righ caster 3.2 degrees
Cross caster -.3 degrees
They didnt do the rear. but the previous owner states that he removed the front drive shaft and it stopped making the vibration. I have not removed the driveshaft to see if he is correct.
The other alignment specs
Front Left:
Camber .1
toe 1/32in
16.8 SAI
16.9 Included angle
Front Right
camber .2
toe 1/16 in
SAI 13.7
Included angle 13.9
Front cross camber -.1
cross sai 3.1
Total toe 1/8
Interested to see what comes of this. I have a bad noise/vibration when decel at speeds 65mph and up. Front shaft is phased and balanced and new u-joints with slee blue bushings in the arms. I haven't measured my alignment yet but was getting close to ordering slees front shaft because my vibration is pretty loud.
are you running drop brackets or caster plates as well as the bushings? that number seems high for a 5.5" lift. I had a 4" Slee lift with Slee arms and had 4* caster, and the arms correct for WAY more than the bushings.
X2, that's a serious amount of caster out of bushing with that amount of lift.
Measure the distance from the center of the hub to the underside of the fender. You want the tape measure to be straight and not curved around the tire.
If indeed all you have in there are bushings then a DC shaft is not what you want. The pinion angle will be way out of spec for that front drive angle.
I just have the OME caster correction bushings ( i think its a ome jspring lift) that supposidly corrects for 2 degree caster. I have the plates, but not installed.
Even though the Yellow OME bushings provide 2 degrees of caster correction they actually rotate the axle by 3*.
Now the specs for a DC shaft is a front u-joint angle of 0* + 1*.
To get the pinion angle at that spot you need to rotate the axle 7*
So 7* - 3*(OME bushing) = 4* u-joint angle. That's not even close for the drive shaft.
Also a 5" lift requires way more correction than even a caster plate can provide and your caster readings are way off from reality. I would actually expected them to be about that much in the negative instead of positive.
So whats up with the readings from the alignment shop? Should i try the caster correction plates?
I looked at the rig's for sale ad. I'm guessing he bought the lift kit from Man-a-fre?
From these pics it looks like you have the MAF drop plates up front for caster. That would explain the caster readings...do you have those drop brackets?
here is the link:80 Series Caster Correction
heh.. after further inspection with some buddies here at work. We think it may be infact the rear. The rear diff does point up a bid in relation to the driveshaft, plus i do have a leak in the rear pinion, which may have been caused by the vibration. Guess thats why you don't take the word of the PO.
do you have adjustable rear upper control arms?
has it always been vibrating?
Could have a bad u-joint or out of balanced shaft
I do not have adjustable arms. Its vibrated since i've had the truck ( about 2000 miles). Rear pinion just started leaking a few weeks ago.
could be a combination of both...
Do you have a CDL (center diff lock) button? If so, you could pull the driveshaft and drive around to see if the vib disappears. that will tell you if it's the driveshaft or not...
maybe the pinion bearing...but I dunno without the load of the drivetrain on it.
Put the truck in neutral and (block the wheels for safey) grab that d-shaft. See if it has any play on either end...maybe u-joints bad, maybe pinion nut loose and bearing bad?
Replace the seal if it's leaking bad
With 5.5" you probably need upper rear adjustable control arms to get the angles back in happy range. Do you know if you got the Man-a-fre 5" comp lift set?
The distance from hub to flare on my LX450 is 24 inches. 25 in the back.
Took it to a driveshaft shop this afternoon for the owner to look at it. He just eyeballed it and said the pinion angles on front and rear look ok. the transfer case he said looked a bit out of whack. Suggested dropping the transfercase to mate those up better..
