Drivetrain vibe
so maybe start with adjustable uppers on the rear?
Should i get that pinion seal fixed? Perhaps the bearing is out too?
there are plenty of trucks out there in your height range that don't have these installed. But you have some very different components on there so maybe these can be used to compensate for other short comings and get things to run smooth.
I know you have said the rear panhard has been addressed but what about the front?
You might consider posting some pics of these scabbed on pieces such as the drop brackets and rear panhard so everyone might get a better idea of how things were done.
Here is a pic of the rear end. Showing the drop bracket on the panhard rod.
Welded on rearpan hard bracket closeup
Found a tag on a rear spring with OME numbering (863J)
Rear diff with driveshaft out, and upper control arms
Closeup
Front lower control arm drop brackets (welded on)
Double cardian drive shaft up front
Front left
Front view panhard
[imghttp://durrer.net/gallery2/d/6740-2/IMG_1958.JPG[/img]
And the bumper is finally done and installed
sounds like you've got a J spring lift on your cruiser. Do you have spacers on the front? J is like a 3" lift up front, closer to 4" in the rear...with a spacer up front, you are closer to a 4" lift.
Also appears you have caster bushings AND dropped control arm brackets for caster up front.
I can't tell in the pics if the rear is pointed correctly or not, but at just a rear J spring you shouldn't need upper rear control arms.
I would replace that pinion seal, make sure the nut is tight to correct preload.
I would also replace the u-joints if they are bad. It's possible if they are original that they developed a wear spot, so when he lifted the rig it's now rubbing in a different spot.
I have the driveshaft off.. and there is zero movement in the ujoints.
it's possible that if they haven't been after the lift, that they could have had a wear spot...then the lift changed that and now they are vibrating...
possible...
I would got after that leaking seal first, make sure nothing seems wrong in the 3rd member at the pinion...
You might also try pulling the front d-shaft and see if the vibration goes away too...
If it does, I might continue to lean more that the drop brackets + caster bushings is putting you at a strange angle.
just trying to help...
you shouldn't need upper adjustables on a J lift...but it's not like they are going to hurt. it's only money right?
Crap.. that post must not have taken. I pulled the rear driveshaft this weekend and the vibe is gone.
sometimes, pulling one d-shaft will stop the vibration. You should put the rear back on and then pull the front to see if the vib stops or not. If the vibration occurs with the front out...then well you know it's in the rear.
If it's gone with just the front in...then...well..:)
Yeah.. your probably right. The front was just such a pain to get to the bolts. Have to take out the xfer case skid too.. But I should probably do that . I'll try to get that done tonight.
Did you try moving it without the CDL locked?
Just trying to rule the VC out as a culprit...
FWIW, I turned off the CDL . drove about a half block or so , not above 15-20mph, with the rear driveshaft out. I didn't feel any difference in power. So not sure what that says about the VC.
Dan
