Well. Before i hit up the front. I noticed that the vibe may still be there with the rear ds in. Had a buddy drive w/ me to verify. Sounds like the vibration.. Just very quiet. Could all be in my head, but my friend noticed it too.
So maybe i do need to do the rear adjustables? No spacers in the rear. So should be just a 3inches with the j springs. I bet the po added the front spacer up front to compensate for the load of the arb and winch.
I wouldn't think you would need upper rear adjustables. I ran J springs rears with 1" spacers, so 5" lift and didn't have the adjusters and had no vibs from that. I currently have them, but don't think I need them necessarily. It's possible you need them...i dunno for sure...but I wouldn't think so.
hmmm...maybe it's the rear u-joints have some wear spots if they are really old and you are hearing that sound. If you are in the mood to toss some money, I'd do new U-joints in the rear, upper rear adjustables (do it yourself versions) and fix that rear leaking pinion (making sure nothing is loose or off in the rear end) Then you know joints are good, angles can be set and no problems with the 3rd.
IMO, i still think the front is the main cause...the caster drop blocks and bushings together.
Without the spacer on a J front/J rear. You will have bad stinkbug...the front will probably be about 1.5"+ lower. Most people run that spacer to "level" up a full J-spring lift. Adding a winch and ARB would sag that front even more.
OMEJ front = 3" lift
OMEJ rear = 4"+ lift
