Drivetrain vibe
FWIW, I turned off the CDL . drove about a half block or so , not above 15-20mph, with the rear driveshaft out. I didn't feel any difference in power. So not sure what that says about the VC.
Dan
That says that your VC is probably seized....
Dan
You should have have seen the engine rpms rev like something was slipping prior to actually getting the truck to move.
pull it, if the vib goes away I'd build one from a Tacoma rear shaft.
Rick. that is a little bit of a general statement, isn't it? Yes, as we have mentioned the Koyo joints used in Toyota shafts are good, but that doesn't mean it is going to magically fix a vibration problem if one exists. I know what experience your comment is based on, but we have tons of people running our shafts with success.
If he has a geometry issue then doesn't matter what drifve shaft he runs, it is not going to work. From the later posts it appears that the VC has some issues. I have never really considered to check this in trouble shooting since I always assumed it to be ok. Sometimes we have checked with center diff locked and unlocked to see if the transfer case plays a role.
after working through a couple of vibration issues and having even a brand new one of your shafts be the problem I'm a little leery of them in general.
Even though the truck's setup with some unusual pieces it does seem to have been done correctly. While he might have a seized VC I can drive around with my center locked and not have any vibrations so I'd think the two are unrelated.
I'm sure you're not excited about my opinion on this but it is based on personal experience of more than one truck and I believe it's sound advice. Now if he was closer I'd happily let him install my spare shaft to rule it out, maybe someone around him has one he can borrow.
With close to 200 shafts in the field I am pretty confident that the number of issues we had is very low based on a shaft that is essentially hand made (ie, not by a Toyota shop). I am the first to agree that we had our share of issues with them, but given the availability of new parts, we have to use what we use. If I had the choice, I would do it with brand new Koyo parts, but that is no an option.
Also, the Tacoma shaft is a good solution, but believe me we have also seen those be issues when shops change them to fit the 80.
On the VC, yes I have have tried the CDL thing as well and no changes, I am just wondering if a VC that is partially locked up might behave different, ie, somewhat of a chatter between the front and back. I guess it is easy to check by locking the CDL with both shafts in.
With the CDl locked or unlocked. The car moves forward with the rear DS out. I'd expect it to slip with the cdl unlocked as all power goes to the disconnected DS?
have you tried pulling that front D-shaft off and just running the rear to see if you get any vibrations?
Heh. Working on it. Bolts are not lined up on the rear, so i've got to get it one wheel of the ground. Putting the xfer case in neutral didn't seem to allow the front and rear to rotate independently.
yep. got one wheel off the ground in front, tranny and tcase in neutral. cdl lock light is off. trying to rotate the front ds so that i can get to the top bolts on the shaft on the tc side.
you still have the rear d-shaft attached?
if you do, it will not rotate. The 80's are fulltime so the fronts and rears will always rotate together.
You will have to roll the vehicle fowards/backwards to reach the other bolts...THEN lift up the wheel to rotate pinion to get it to line up to put the other d-shaft back on
With your VC seized up, you'll have to have one front wheel and one rear wheel up if you already put the rear shaft back in....
Even with the center diff unlocked?
Yes, if you have one driveshaft attached and both wheels on that axle(that the driveshaft is attached to) are touching the ground, then it won't turn no matter what the t-case is in or CDL in/out
1 wheel off the ground on that same axle up with should allow for it to rotate IF you don't have the driveshaft shaft on the other axle.
Ok. So makes sense. The talk of Seized VC freaked me out for a bit.
Got the front shaft off. Rear on. Off to work to see if it makes the grrrrr. Will follow up in a few mins.
