Drive shaft 2 Differential
Virginia Beach
Hey ya’ll I finally got around to replacing my rear pumpkin. Got everything put back together and went to bolt up the drive shaft only to realize the bolt pattern doesn’t match.
The holes for the new diff are farther spread apart then the shaft. I need advice on how to make it work And what where to buy. I need to move the truck in a couple weeks to a new house.
Depending on how far your moving can completely remove the rear driveshaft on drive it on front axle. It's the front and rear axle together that is hard on the drivetrain particularly the transfer case. When turning rotations do not match front to rear. Dirt much easier for wheels to slip than on pavement. Now if you do not have a open front diff and have a Lock Right style locker it will not drive on pavement wirhout fighting the steering wheel that only wants to go straight. Might be a easier solution than rushing to locate and install a new flange on the diff. Seems when I rushing things never go right. Just getting ready to move it probably keeping you busy.
2 weeks until I close on the new place and they want me to move it to roof the place we are currently renting. Don’t think I’m willing to drive all the way only using the front but I guess I can pull it up on a dolly that way.
Get on Classifieds here on MUD, swap out the yoke on the driveshaft with one that has the same pattern.
So is there a Historian that can tell me which bolt pattern is applicable to what year? Picture of original removed and new installed. I’m now concerned that my front and rear aren’t the same ratio....
easy to check ratio, rear, jack up 1 side, rotate tire 1 revolution, count the #' of times the pinion flange rotates
front, jack up 1 side, lock hub on other side, then the same thing, rotate tire 1 revolution counting the rotation of the flange
8/84 was the date the bolt pattern on the flange changed. Prior to that was 1/74 for pattern change. If from a US market FJ60 will be 3.70:1. FJ62 will be 4.11:1. But ratios can be changed so really need to check. Another reason to just leave the rear driveshaft off and just drive on the front axle.
If your old one has the same spline count you can swap the flanges. Looks like you went to an older diff than the one you had. I think the 4 bolts changed diameter too at some point. I am sure there are those that have messed with more diffs than me, I have ran into this issue before changing diffs, parking brakes and driveshafts. I have even had fitment issues on the multi pattern flanges. That probably helped you very little, but like others have said, driving in front wheel only is fine, if you don't have a lunchbox locker in the front. Good luck-Matt
I agree with 3_puppies . Rotate the flange until there is room to re-drill the pattern and re-drill. I use centering punches to mark and cobalt drill bits to cut the flange. They are fairly difficult to drill, but not bad. Unless you used a solid pinion spacer , I would leave the flange on the gear set you are wanting to use. Re-torquing a crush sleeve setup is a bit of a crapshoot unless you have a very good understanding of how all of that works.
Looks to me like you have an early 70s diff flange and a mid late 70's drive line
Not sure when the round flange started but my 3/79 does not have one. Have a what I think is either a 5/84 or 7/84 rear axle from Australia. It has a round flange. I show 1/78 for a change which believe is coarse to fine spline but shape of the flange did not change 1/78.
Until he figures out what diff ratio he has wouldn't bother drilling the flange. I know if I was about to move would be worried about the move not getting the rear driveshaft hooked. My guess is he has a 8/84+ rear diff. OP never stated what year or transmission his cruiser is. My guess is he has a seventies cruiser with a four speed.
The fine spline diffs started before 78'. Just because it is a round flange does not indicate a year as there are many aftermarket flanges , I believe theat oem did go to a round flange in 78/79 on the 40 series.
