17 posts in 8 years and you hit us with this, yeah gonna need a lot more pics![]()
YayX2 besides it have totally " bolt on " all over it ..
You can’t because of the gas tank. You can run a 3-link but no real value.Does anybody have an updated picture of the geometry for this triangulated 4 link? I’m nerding out while bored at work
@ThreeEyedBandit has a setup similar to what is posted by a couple different members in this thread with the wishbone upper.Does anybody have an updated picture of the geometry for this triangulated 4 link? I’m nerding out while bored at work
forum.ih8mud.com
This is a thread about a double triangulated 4 linkYou can’t because of the gas tank. You can run a 3-link but no real value.
I was playing with numbers today and was looking for a the “after” geometry photo@ThreeEyedBandit has a setup similar to what is posted by a couple different members in this thread with the wishbone upper.
He shared a couple photos here:
Why arent people 3 linking the rear of built 80’s?
forum.ih8mud.com
edit: or were you asking for the missing "after" geometry photo on post #1?
Ya...so he 3-linked it with a wishbone and extended his lowers.@ThreeEyedBandit has a setup similar to what is posted by a couple different members in this thread with the wishbone upper.
forum.ih8mud.com
It was until OP realized you cant run a triangulated 4-link...unless you want to tri-the lowers below the diff...This is a thread about a double triangulated 4 link
What does your geometry look like?Ya...so he 3-linked it with a wishbone and extended his lowers.
His geometry is so ****ed....
Not finding the image, maybe he removed it on purpose? Some more photos of the setup here....I was playing with numbers today and was looking for a the “after” geometry photo
forum.ih8mud.com
Yes but it function the same as a double triangulated 4 link.Ya...so he 3-linked it with a wishbone and extended his lowers.
Have you actually looked under your cruiser?
So this is on the YJ, not the 80 series? Or these numbers are for a system built on an 80 series?For the cruiser? Run of the mill, for my other two rigs than run dual and single triangulated I can post those but they arent an 80. His upper links should be close to 80% of the link of the lowers.
Heeeyyyy nice it’s the good calculatorFor the cruiser? Run of the mill, for my other two rigs than run dual and single triangulated I can post those but they arent an 80. His upper links should be close to 80% of the link of the lowers.
They dont function the same, about the only function thats the same is it can eliminate the trackbar.Yes but it function the same as a double triangulated 4 link.
Could you explain to me how his geometry is bad? Did you plot it?
No I’ve never looked under my Land Cruiser.
That screenshot was of the 80. I have a YJ and an LJ. I pulled the 80 in the garage to double check my numbers since I didnt spend a lot of time on it.So this is on the YJ, not the 80 series? Or these numbers are for a system built on an 80 series?
Stock 80? Sorry, just trying to understand what you are trying to communicate.That screenshot was of the 80. I have a YJ and an LJ. I pulled the 80 in the garage to double check my numbers since I didnt spend a lot of time on it.
I can't plot his perfectly without spending some time studying his pictures and getting them perfectly lined up (which I dont really have a desire to do)
However, the key thing is he extended his lowers but used the factory crossmember for the uppers. Take a look at my LJ suspension geometry, the one on the left is the custome triangulated suspension I built, the one on the right is if I left the factory upper control arms in the same position, even if I triangulated them, look at the antisquat numbers alone, then imagine what his pinion angle change is during the suspension cycle. Rule of thumb is upper links are 80% of the length of the lowers.
How do they not function the same?They dont function the same, about the only function thats the same is it can eliminate the trackbar.
