Are the 3rd gen 4runner dc joints beefy enough for hardcore stuff?
Well, I snapped one axle and spun two axle shaft' splines with mine if that helps?Are the 3rd gen 4runner dc joints beefy enough for hardcore stuff?
Snapped the u joints?Well, I snapped one and spun two axles with mine
Im asking about actual hardcore use though... not driving like a schoolgirl on the rubiconEdited, snapped LR axle, and spun both shafts' splines (stock shafts)
You prick!Im asking about actual hardcore use though... not driving like a schoolgirl on the rubicon
After lifting an 80 series past a certain point and or correcting the front castor to account for the lift, a double cardan (DC) joint drive shaft will be needed. Slee Off-Road offers an excellent solution with all new quality Spicer joints and also a local drive shaft shop can make any custom shaft for your needs. However, my personal preference is to keep with Toyota Koyo joints AND half the price of a new shaft. There is a Toyota solution for both the front AND rear of the 80 series.
Double cardan shafts for the front
The most common has been to find a rear shaft off an '95.5-'04 extra or double cab Tacoma. The bolt patterns will match at both the pinion and t-case, however the Tacoma shaft is longer in length. A competent drive shaft shop can easily re-tube it to the needed length. The other solution is to use the rear shaft off an '00-'07 Tundra extra cab, which will also need to be shortened. Both solutions are cheap, costing half the price of a new shaft and you will have Koyo joints.
Here is the Trundra shaft on the front t-case:
Double cardan shafts for the rear
Keep in mind that the bolt pattern and bolts on the rear shaft of the Land Cruiser are BIGGER than the front. It is possible to use a rear shaft off an '96-'02 4x4 4Runner. The bolt pattern will ONLY match at the t-case. The 4Runner uses a smaller slip yoke and flange at the pinion. The only solution is to have a drive shaft shop re-tube the shaft with a new slip yoke and flange to match the Land Cruiser's pinion OR cannibalize your original shaft for the slip yoke and flange. This shouldn't be much more trouble since the 4runner shaft is longer and needs to be cut down anyway. This would also be the time to use thicker tubing.
Here is the 4Runner shaft on the rear t-case:
Also the front shaft from a pre-'84 FJ60 will not idealy work in the rear becuase a change in flange designs. Front shafts off a pre-tacoma or '84-'95 4Runner will also not work on either the front or rear of the 80 series. However, the DC joints from these shafts can be used if the LC's tube with slip yoke flange is matted to then. Then the flange(s) on the t-case must be drilled to accept the new bolt pattern from these joints. I would consider this a less than ideal solution but no less a possiblity.
From what I understand, Toyota only sells complete propeller shafts themselves. If you have a driveline shop in your area that knows what they are doing, go there and see what they can do for you. I started out going the 4runner route but ended up taking the advice of the driveline shop that I have done business with for many years and let them build me some DC shafts out of brand new 1310 size stuff. Toyota parts that are not warn out are getting so hard to find that U.S. manufactures are making yokes to fit the Toyota outputs with no machining except for flange thickness...So I just picked up my donor driveshaft from 2001 Tacoma. Went to the part store to get replacement u joints and they are telling me they don't make replacement parts?? Please tell me I am missing something.
Adapted to the toyota xfer case?Look all over pirate and you'll find that Toyota CVs are stronger than 1310 cvs and maybe as strong or stronger than 1350 cvs.
Myself I have 1350 cvs front and rear.
Spicer and/or Neapco are making 1310 CV's with the correct bolt pattern for our Toyota application. The only modification necessary is to machine the flange thickness down to a max of .300" in order to have a thread or two protruding past the nuts of the flange studs.Adapted to the toyota xfer case?
I know - have one. But was surprised about a 1350 cvSpicer and/or Neapco are making 1310 CV's with the correct bolt pattern for our Toyota application. The only modification necessary is to machine the flange thickness down to a max of .300" in order to have a thread or two protruding past the nuts of the flange studs.
