A comp test two years ago before the overheating problem developed really has no bearing. A test a couple of days before the problem developed means nothing. Check it. It is quick and simple.
Mark...
Mark...
Make sure your system is properly filled with no air bubbles. I don't know what your upper radiator hose is like and if you are easily able to burp it using that. This is where flexible rubber uppers are handy instead of Reinforced acordian hoses.
Since you have already tested your thermostat, beyond this i would look for pinholes in the radiator, then head gasket last, especially if there is a loss of coolant with no visible leak anywhere.
It's really hard to fit a fanclutch in front of a 2F in a Pig. Toyota only did it in '78 when they put a 2-row radiator in the 55.
Pigs with 2Fs just do not run hot unless something is really wrong. If the waterpump is not leaking out the weephole, it's probably ok. Run your pig without the thermostat, see if that helps. I might pull the radiator and either give it a muriatic acid soak or have it rodded at the radiator shop. Check the big radiator hoses too, I have heard of them disintegrating on the inside and blocking flow.
But if you're blowing off the top of the overflow bottle, I'd do a compression test to rule out the head gasket...
Not trying to divert your thread, but I have a 2F from a 79 55 that I am installing into my 66 FJ45LV. Will the stock fan clutch setup work? How do I know if it will work? Is it a matter of if it fits it will work?
Shop says there is no trace of emmisions (carbon) in the coolant. Thusly they do not think it is a head gasket......Claims it is circulating.....did ask if it was the original radiator.....I am at a loss. Maybe I should buy a new radiator. Thoughts? I did go to the dealership in town and order an OEM thermostat because the one I have is Autozone or something. In all my spare time I will change out the therm with the OEM....thanks for the help and advice everyone....
Randy
Water pumps do not "work a little bit". The work or they fail. No in between.
and steam came out of the hood vents
