Dobinsons suspension components breakdown for 80 series
crikeymike
ExitOffroad.com - Dobinsons Specialist
Supporting Vendor
Jacksonville Beach, Florida
Website
exitoffroad.com
We get calls from customers asking when they should buy a castor kit, or if they need castor plates, and what they need to do to their sway bars, realigning the front or rear axle, what size coil spacer (or trim packer) to use, and all sorts of suspension related questions that are separate from coils/leaf springs and shocks. I've seen a lot of people over the years lift their vehicles in all sorts of ways, but some of the other components are being strained and not corrected during the lifting process. I can also tell based on how many coils and shocks we sell, yet the quantities sold of these parts below aren't proportional all the time.
I want to point out all of the common Toyota suspension components that we make related to all that, and hopefully bring some friendly education to anyone that needs it. Feel free to add any comments or suggestions, as well as questions about these parts. I'll start with 70 and 80 series parts, then I'll add anything else I can find as I get to it.
To order, everything for the 80 series is listed here: 80 Series Land Cruiser (1990-1997) Archives | Exit Offroad
Castor Bushings
Lifting over 2"? The angle that the front control arms will hold the front axle in place will not be the same any more (castor angle). Most of you know about this already.
We offer rubber bushings, set to give 2.5 degrees of castor correction. We have these for 70, 80, 105 series, with the 70 series being the rarest and also most expensive to correct.
And also adjustable poly bushings, to give 0, 2.5 or 3.5 degrees of adjustment, based on the removable steel sleeve insert (it has 4 clockable positions).
We also have fixed replacement poly bushings for all ends of front and rear control arms, panhard rods for those that are interested.
Castor Plates
Lifting over 4"? Leave the stock bushings alone and add these to the axle end to give 5 degrees of castor angle back into your vehicle and make it driveable. They're zinc plated (gold). Oh, and it's not recommended to combine these castor plates with castor bushings.
Coil Spacers
Old sagging coils, leaning problems, or not happy with the final lift height of your new suspension? First you should make sure everything was installed properly and on the correct side. Then if you still need a boost, we offer 5, 10, 20, and 30mm coil spacers for 80/105 series front ends and 10, 15, 30mm coil spacers for the rear end. They're polyurethane and will last a very long time, and are pretty straight forward to install.
Rear brake adjuster
The rear brake system on the 80 series is easily affected negatively when lifting over 2". Many adjust it properly, but some just leave it alone. Our brake adjuster is that shiny gold vertical bit on top of the diff. It sets brake bias back to where it's supposed to be, based on the amount of lift (comes with instructions on setting it right).
Adjustable Panhard Rods
Available for some vehicles front and rear (80/105 series) and rears of FJ Cruiser and 4Runner (although not needed very often for these). The 80 series suspension design pushes the axle assembly to one side of the vehicle, as the original fixed length panhard rod is limiting it from sitting straight. Our adjustable panhard rod can fix that and set your front and rear axles back into center. They're pretty easy to adjust, but one end must be taken off to set the length (not on-car adjustable).
They have been gold zinc coated for years, but we have just added black powder coat over that layer so they look all black now. 2 layers of corrosion protection
Front Swaybar Extensions
For the front of 70 and 80 series cruisers, these will lower the rear end of the sway bar so that the sway bar can sit more level without putting pressure against the bushings, and also keeping everything working properly. Gold zinc plated once again, super easy to install, and definitely should be installed for anything over 2" to 6" of lift.
Rear Swaybar Extensions
Some 80 series used a swaybar system that attached to the side of the frame, while most that I've seen here in the states use brackets that are attached to the bottom of the frame. We offer both styles. I'll update pics once I get the side-mounted ones in. Recommended for 3-6" of lift.
Castor Correction Kits
*PB59-503K
Polyurethane adjustable castor bush kit, 0*, 2.5*, and 3.5*
*RB59-522K
Rubber 2.5 degree castor bush kit
*WA59-514K
5 Degree castor plate kit
Brake Adjuster
*BA45-005
Rear brake adjuster
Swaybar Extensions (pairs)
*SE59-516
Front Swaybar extensions (pair)
*SE59-517
Rear Swaybar extensions (pair, side chassis mount)
*SE59-519
Rear Swaybar extensions (pair, bottom of chassis mount)
Panhard Rods
*PR59-1408
Front LHD Adjustable panhard rod
*PR59-1405
Rear Adjustable panhard rod
Front Coil Spacers (sold individually)
*PS59-4003
20mm
*PS59-4004
30mm
Rear Coil Spacers (sold individually)
*PS59-4006
15mm
*PS59-4007
30mm
OE Replacement bushes
*RB59-536K
Radius Arm Bushes, Control arm to diff, 4 x rubber bushes
*RB59-534K
Radius Arm to chassis bush kit, 2 x rubber bushes
Rear upper and lower trailing arms
exitoffroad.com
Dobinsons Adjustable Rear Lower Control Arms Pair | Land Cruiser 80 Series
Dobinsons adjustable rear lower control arms, to be used on any 80 Series Landcruiser lifted or not, up to 7" of lift, increased strength
exitoffroad.com
exitoffroad.com
exitoffroad.com
Dobinsons Adjustable Rear Upper Control Arms Pair | Land Cruiser 80 Series
Dobinsons WA59-545K adjustable rear upper control arms for an 80 series Landcruiser lets you set the pinion angle properly for alignment
exitoffroad.com
exitoffroad.com
If anyone has photos of these parts installed in their own trucks, please post them up for better visuals!!
They're $225ea plus shipping. They use an OE style rubber bushing.
Where can I go to get a spec chart of the available coils springs for the 80 series. I would want to see free height, turns, wire dia, spring rate etc...
Coil Springs
Careful, there are over 30 options for the 80, so feel free to PM me with what you're interested in to narrow down the choices
Coil Springs
Yeah, I see listing of coils but no specs of free height, turns, wire dia, spring rate etc...
If you could just give the specs of the 3" & 4" STD & HD coils that would be great thanks.
I forgot to post up that we have OE style rubber centered front control/radius arm bushings, fixed end and axle end. Here are some pics of those.
Frame end, RB59-534K (contains 2 bushings)
Axle end, RB59-536K (contains 4 bushings)
Frame end, RB59-534K (contains 2 bushings) $50 per kit
Axle end, RB59-536K (contains 4 bushings) $105 per kit
Sorry about that guys, there you go.
Bump for available. Bent a factory arm and looking to replace. The Dobinsons arms look like a great option.
Yep, had them for a long time now, sorry. Time to update the thread.
