Distributor Qs
Roseburg ,Or
Hey guys- 74’ fj40 with vac retard distributor and Pertronix installed. I have a 78’ vac advance distributor and a coil/ignitor from an 86’ fj60.
Looking to upgrade to vac advance. Is the 78’ the way to go, or should I grab a City Racer distributor and swap the Pertronix over?
Similar question, fj40jim chimes in
2F swap ignition help
All the 78-87 dissys and ignitors are compatible with each other. So a 79 dissy will trigger an 82 ignitor, or vice-versa.
The wiring from ignitor to truck body changes slightly, but the coil to dissy wiring and impedance is the same.
The 78 dissy has a ballbearing shaft and is waterproof.
The F dissy shaft run in bushings, which wear pretty quick. The 78-newer run in one or two ball bearings which usually last the life of the vehicle. The Denso electronics are very robust as well, so age is not much of a factor for that.
CarQuest.
Not that you need to, but you can pull that 78 dissy apart and clean the bearing plate(I think FJ40Jim says it has the barings) I pulled a 81-87 big cap apart cause the shaft felt a bit gummy.
