Disc brake conversion advice
Grants Pass, Oregon
I just joined this forum and am glad I did. I bought a basket case but solid '71 FJ40 recently and am starting to order parts to prep for some winter build fun. One of the things I want to do is swap to discs all around, and I see the GM swap seems like a good setup with Monte Carlo calipers in the front and Eldorado in the rear, both ends using GM rotors. My question is, what's a good bracket to use? I found some from JoeTLC on ebay, but after a search on here, I'm thinking that is probably not going to work out. So my question is, who's a reputable manufacturer/seller of quality brackets like this?
@Poser here on mud will set you up with rear brackets
for the front, go mini truck or landcruiser knuckles out swap
I appreciate everyone's response, but here's my reasoning for swapping to GM brakes: here in Southern Oregon, Toyota 4x4 parts are high priced, typically beat up and hoarded like gold. I agree 100% with melvinjo, there's just not a lot of these things around and they too fall into the "gonna fix it up someday, so don't low-ball me" column. I was just hoping for a good source for brackets that those here have used with good results.
A front disc upgrade with a 'kit' or bracket is not nearly as safe as factory designed components. You just need some patience. Knuckle swap parts or whole axles (late FJ40, FJ60/62 or Mini truck) show up. You can also look for a FJ60/62 being parted out. Post a wanted ad here in the classifieds.
You will be a lot happier and safer doing it right the first time.
Oh yeah, welcome to Mud :flipoff2:
X100
Every few months I see axles locally. Couple weeks ago, $150 obo for both axles. So they are available.
Keep your eyes on Mud classifieds or call around to some of the decent mud vendors and you can pick up only the parts needed for between 2 and 3 hundred. Your axle housing with a little grinding will accept FJ60 inner axles, birfs, knuckles, spindles and brake parts and you won’t have to change line routing or pinion flange. The calipers on the 60 arnt much smaller than on my 14 sequoia. I’m not real impressed with the Chevy calipers and mounting options. They look great for rears but I wouldn’t want them for fronts.
In Vancouver BC there are a couple 60 series advertised for parts. EBI cruisers could likely also ship you what you need. 60s all rot out in the rear of the frame in these parts... so lots are being parted out.
