Diff gear chunk
Durango, CO
Website
www.kindel.com
So I get my rear diff cover off and I'm wiping as much excess oil out of the casing as I can and I feel a chunk of metal down there.
Out comes the chip in the first picture below.
My 10 year old son says "that's not a good thing, is it dad?". I say, no it's not.
He says "how bad a thing is it dad?". I say, I think it's really bad. But lets take some pictures and post them to Mud and see what the experts think...
The 2nd picture shows the tooth (not quite sure what that particular gear is called) that the chunk is missing from.
So?
Broken axle side gear...no biggie, as long as the rest of the ring and pinion do not look shelled...
Found anything else amiss?
How much metal was on the magnetic drain plug?
You should not have an issue getting a set of side and pinion gears from someone out here...
Good luck!
-Steve
There were a few metal shavings on the plug, but nothing that would have shocked me.
Is this a sign of impending disaster...do I *have* to replace the side and pinion gears?
I gotta take the 3rd member off to replace the gasket anyway... How hard is it to take it all apart...and more importantly put it back together correctly? (for a dummy like myself).
It is really not that hard to remove and replace....
You do not want to continue to operate that diff like that....at least I would not do that. The chassis and body manual clearly cover R@R of the center section on the rear axle.
You have PM. :)
Good luck!
-Steve
If it's not a dd put an aussie locker in for about $230. Actually I think I have some of the gears sitting I might can sell them to you. for say $40 plus ride. does that soumd fair? Does the 6/1977 fit in that one? I'll send you all that minus the upper left piece.
Got the 3rd member off. Once I did that it was pretty obvious how it came apart/went together. I followed the instructions in the FSM noting left and right spacers. It's the left gear that is damaged.
While I'm on the subject of my rear diff
My rear 3rd member housing has been welded. I wasn't sure how severe the original cracks were until I had it opened up and was able to look in side. The crack is pretty substantial.
I couldn't get a big picture of it, but when looking inside the casing I can see a substaintial dent/crack.
The weld looks pretty good, but I wonder if this might be a location where I'm leaking... Should I get it re-welded?
What does a used, but in good shape, casing go for?
Looks like a bandaid to get by with to me, NTTAWWT but I would always be leary of it. Heck man while your at it I'd hunt down a decent 3rd and stick an Aussie in there and call it good. JMO
Oh, and I just use silicone, no gasket, between the axle housing and the 3rd.
I second that.
No Aussie for me. This is a DD that will rarely see the trail.
I already have new OEM gaskets and plan on using those.
A casing from SOR is $49. but that means I have to re-build the whole 3rd.
I'm in the process of taking the front one off right now. Maybe I'll just put it on the back, replace the side and pinion gears on this one and put it on the front.
This keeps up and before long I'm going to be an expert...providing help here instead of just getting it:beer:
sounds like a plan to me , then you have a nice low mileage third in the rear , sweet ! that is if you are pulling the font end apart anyways , are you going to rebuild the front axle when you are in there , knuckle rebuild kit . then you have a tight rear third ,and also a rebuilt front end new gaskets bearings and seals ,
You don't HAVE to rebuild the front hubs to take out the third member but you do have to slide the axles out of the spider gears. For me that would mean I'd rebuild the hubs as part of the job UNLESS the hubs are recently done. If they are recently done then I'd be careful with the seals so they could be reused and go for the differential only.
Oh, no 'C' clips in front, before you ask.
Yea, I kinda figured that.
Well I guess I'm at a key decision point then...
Option A: Cheap & Fast - but not Right
  • Ignore the diff leak up front. Just live with it.
  • Buy a new set of side and pinion gears for the rear diff and don't worry about the casing.
  • Re-do my front steering (both tie rods are bent, tie rod ends are shot)
  • Get the rig back on the road in a week or two.
Option B: Do it all Right and right now
  • Commit to leaving the rig on jack stands for at least another month, perhaps longer given how much a newbie I am
  • Buy a "new" used 3rd for the rear
  • Take the front axles apart, re-build the hubs, fixing the front 3rd gasket leak in the process. The front hubs seem fine, I have no documentation showing when they were rebuilt. Lots of gunk build-up around them, but I don't think that means anything.
  • Drop the tranny & tcase and inspect/repair/rebuild as needed (there was a fair amount of metalic sludge in both and the seal between them is done).
  • Buy that 2.5" spring kit I need to replace the tired original springs and install that.
  • Risk burn-out
I think I'm going with Option A. The front diff leak is not horrible (the oil pan gasket leak is the biggest problem). The rear diff casing is probably ok for driving to/from work. And as much as I'm enjoying wrenching on this thing and learning, I really, really, want to be driving it. But I'll stew on it for a while...
