Diff gear chunk
If it is not leaking oil from the weld area, I would not stress it....If you come across another center section, replace it, otherwise I would run it.
:beer:
after all this ,, i may have a empty third you can have if ya come and get it i also have some tie rods laying around , how far from the border are you , i'm right at the blaine truck crossing , i do not want to ship too lazy also have a few set's of the spider gears you can have em also
Plan B - you won't burn out - it's not hard, and not that much work in it - but you might have to wait a bit to get the parts together. Cost isn't too much if you don't rush in. Spider gears aren't worth much to someone who's put a locker in, and diffs aren't worth a lot either.
If you want to keep it on the road - pull the rear driveshaft & just use 4WD with an empty rear housing till you get the bits together. Then do it all in a weekend. Just make sure you clean the housing well before re-assembling.
i could maybe meet ya somewhere . but ya might have to fill up my tank ??
I may take you up on the tie rod (i think I have a line on a relay rod), but i think I just found 2 3.73 3rd members from a '79...which will be ideal!
muddy12 said:
Oops - my last post will only work if you have full floating rear axles....
No worries. Point is moot anyway as I have decided to Go Big and go with Option B.
Yay. I finally got some time do dig back in and get my hands (and face) dirty.
I made huge progress on getting the cork oil pan gasket material off of my block. The rear arch part and the sides are so clean you could eat off of them (assuming you could eat Michelangeo style...upside down). The front part is still a bitch because the gasket is even harder that the rear was and the front diff is in the way.
So...
I know I need to pull my front hubs off inorder to install the new 3rd member (I found some 3.73s from a '79!).
I also know I need to pull my steering stuff apart.
I also know I need to pull my springs and axles off in order to put my (yet to be ordered 2.5" spring kit).
I also know that I am really not prepared to pull the front hubs off. I really have no idea what I'm doing, and there's all this terminology and SSTs and crap in the FSM and Hanyes that I know I can figure out but I'm just not ready to dig into that yet.
So... Should I just pull my steering stuff and axle off now and do the 3rd member & hub rebuild while they are off the truck? Or will that make it harder to work on for some reason?
Bull, thank you. Got the left one done...
Now I'm confused on what rebuild kit to order from SOR.
080-41B-KIT Major Shim & Gasket kit ($50.45)
080-400B Knuckle Bearing Kit ($94.50)
It looks like 41B is a sub-set of 400B; the 400B contains the bearings. My bearings *look* OK. Thoughts?
Poser said:
Post up a couple pics of the race in the knuckle....
I would just replace them.....but that is just me.
:beer:
Two pics of the knuckle. The races look real purty to me, but what do I know.
FWIW, I'm going to order new bearings anyway...that's just me :grinpimp:
Oh, and I got the other side disassembled tonight too. And the 3rd member out! Yay!
:cheers:
bull said:
Did you baggy and mark where your shims came out of?
Yep.
But...if I'm replacing the bearings, and the rebuild kit comes with new shims, don't I just need to keep track of what # of shims there were?
