Diesel conversion Phoenix area
kdxman
Mesa AZ
Dose any one have first hand experience with the AZ emissions test for a diesel conversion here in the phoenix area I thinking about putting a GM 6.5L in my 96 LC But I'm a little concerned about the emissions test. Any help would be greatly appreciated, also I have used the MUDsearch already and not found any really solid answers.
A few years ago when I was interested in putting a different engine in my FJ40, ADOT informed me that if I did an engine swap, the replacement engine had to be at least the same year as the vehicle it was being swapped into. Don't forget, diesels for the most part don't have all the emission accoutrements that gasoline vehicles do.
As far as emissions goes, as long as it passes the opacity at load test, which is basically running on the dynometer, there really shouldn't be an issue. I just ran my BJ73 though about a month back and even though I haven't dialed in everything as I would like it, I was far under the opacity requirement.
Personally for me, there are MUCH better options for a diesel swap than the GM diesel; unless you are looking to swap in an Allison automatic transmission specifically, I'd look into a Cummins, or even the Isuzu swaps would far outweigh the GM.
There is a few 80s with the 6.5 that run very well. If you take care of a couple small things the 6.5 is a reliable setup that is much more drivable and smoother than the 4 cylinder cummins or izuzu. Right off the bat its has 90 more hp and 150+lbs of torque with a much wider power spread plus the 4l80e behind it is setup to have decent shift points. The 6.5 has the 4l80e not an allison...
Stock it had some crappy issues but if you take care of them its a decent setup with great mpg and its a very reasonable swap because it goes in like a sbc.
The easiest way would be to make sure that you pluck a 6.5 out of a 96 or newer chevy and you should be fine.
why :confused:
Just go with a company that makes diesel technology their priority. The 6BT or 4BT cummins will be around longer than your grandchildren's grandchildren; Isuzu has been making diesel engines commercially longer than ANYONE, even the Germans. The GM diesel will last about as long as chumbawumba.
Strictly Diesel Home Page should be able to answer all your questions.
I've been thinking seriously about a Mitsubishi/Fuso 4cyl diesel swapped out of a late-90s Canter/FE4xx in my 80. They have a very similar trans (made by Aisin, no less) to the 80. Might be easier to fit the transfer to it.
Another choice is the Isuzu 4HE1-T. Fully mechanical, 4.8L turbo and plenty torquey. It also has an Aisin behind it, but it's an A450-43LE. Doesn't look like the LC tranny, but locks up in 2nd-4th gears.
Plus I have far more experience working on these. (The 1 FE I worked on only ever had a single problem in over 400k miles, and that was the pump going bad due to the new ultra-low sulfur fuel.)
I'd avoid the Isuzu 4HK1-T and its derivitives. Great motor, but shakes worse than any other I've seen. And it's fully electronic, common rail with a variable geometry turbo and 1 of 2 types of particulate filter systems that are a huge nightmare, maintenance-wise and financially.
Nissan diesels are a possibility. I have limited experience with them, and in an off-road only application.
Nothing actually wrong with a 6.5, I just think you'd have better luck with a Japanese motor.
You should talk to Sheldon of G&S Cruisers 604-791-7993 - he did the wiring on Greg's 1 HD-T turbo diesel conversion (Greg was at Cruise Moab) in his 80 series. Greg's truck was getting 19- 20 mpg on the way down to Moab.
Although, Sheldon is in Canada he may have a good ideas for you to consider.
There are a few reason I chose the 6.5, I can get parts at about any parts store, it has about the same weight as what in there now, its quiet and smooth for a diesel and the after market blocks eliminate most of the problems the factory engines had. I have been talking with Tor from Toyota off road fab so I'm not worried about getting it in and running the only thing I'm concerned with is the AZ emissions. Thanks HJ60 I have sent strictly diesel an email.
I still ask: why :confused: is your current motor not running or something ?
and: why would you piss your wife off by suggesting she bought you something that isn't good enough ?
wasn't she the greatest wife just a couple days ago ?
Maybe I missed it somewhere, but why do you want to swap engines? Got a blown engine(unrebuildable), want to pull a 30' Airstream? If you just want to wheel most of Arizona, Utah, Colorado, etc, then what's wrong with the OEM motor? It serves a lot of us quite well. John
:doh:
First off I informed the wife (who is still the greatest) from day one that I was planing to swap out the gas motor for a diesel. My personal preference for wheeling is a diesel I have nothing bad to say about the motor that's in the LC now I quite sure it would run for just about for ever with the proper maintenance.
If Toyota would sell diesel LC in the US it would save me the trouble of having to get one installed in the first place, but they don't and unless I get a full size pickup truck or suburban there not any options with a diesel. So my options are full size truck or sub witch I don't want or a LC that need a little modification. :D
Shouldn't have to justify a thing. It's yours, build it the way you want.
He doesn't have to "justify" anything to me. I was just curious about his personal reasons. Hate the gasser, love the diesel, blown up engine, free donor diesel rig, need/want much longer range on given amount of fuel, etc. At one time I was very close to doiong a 6.5 and NV 4500 in my Piggy. I was going to use the first year model of the 6.5 (93, I think) as it had no computer, so nice simple diesel. John
My comment was not directed at anyone in particular. It was just a general comment to the thread, too often people question others' build choices simply because it isn't something they would do. I actually borrowed that line from an Oldsmobile forum, it's a nice way to quite the purists.
If I had to guess why he wants to drop a diesel in his 80, probably because he wants a diesel 80. :)
Cheers!
I am starting to collect the parts to build a Cummins Lexus :). Also going to start offering gm v8/ Diesel swaps for those interested.
There was a time in this state, within the emission testing areas, that you could swap a 6BT into anything and get it passed but a few years ago that changed. The state now takes into consideration the GVW of the vehicle that it came out of and the new vehicle must be at least the same. This was discovered by a friend that is a Cummins mechanic. He swapped in a mid 90's 12valve into a Ramcharger.
When he went to get it through emissions it failed not due to the output but the GVW of the Ramcharger, it was less than the OEM spec for the engine, 3/4 or greater vs the 1/2 he put it in.
He spent several months working the issue with the DMV and ended up selling the truck out of state as he could not find a way around it.
If you are outside the emission testing area its a mute point.
For the 6.5/6.2 it should not be an issue as there came in 1/2 ton GVW vehicles similar to the LC. However its the government so who knows what they will enact next to restrict these swaps.
