Diesel conversion Phoenix area
There was a time in this state, within the emission testing areas, that you could swap a 6BT into anything and get it passed but a few years ago that changed. The state now takes into consideration the GVW of the vehicle that it came out of and the new vehicle must be at least the same. This was discovered by a friend that is a Cummins mechanic. He swapped in a mid 90's 12valve into a Ramcharger.
When he went to get it through emissions it failed not due to the output but the GVW of the Ramcharger, it was less than the OEM spec for the engine, 3/4 or greater vs the 1/2 he put it in.
He spent several months working the issue with the DMV and ended up selling the truck out of state as he could not find a way around it.
If you are outside the emission testing area its a mute point.
For the 6.5/6.2 it should not be an issue as there came in 1/2 ton GVW vehicles similar to the LC. However its the government so who knows what they will enact next to restrict these swaps.
My parents have an f350 and were paging ridiculous high reg fees on it annually. Turns out someone who did the reg on it had the gvw at 25k so they dropped it considerably and cut their fees almost in half. Maybe we can have weight added to adjust gvw?
Correct GVWR is listed right on the ID plate. AS much as I like to liken the 80 to a 3/4 tone station wagon, you may have a lot of resistance in registering it as such. John
All my vehicles are reg in Santa Cruz county so no smog test for me but right now I will pass with my 6.0. When I did a Cummins 4bt build I was told by MVD that the motor had to be the same yr or newer than vehicle it was going into. So I'm not 100% sure if gvwr plays a roll in whether you can do the swap.
