My rig is overheating and I want to try and find out why.
It’s a 2002 with ~225k and is our family hauler DD.
Today my father in law called me and said he drove it to his house (~5 miles away on country road) and it overheated into the red on the temp gauge. I forgot to ask him what temp the Scangauge read for *fWT since I keep it hooked up on the steering column. He said he popped the hood, everything was normal except the coolant reservoir was empty. Radiator level was fine and normal looking red/pink for Toyota.
Thinking it was for sure a busted heater hose tee, as it’s the originals at 225k, I went and bought two new ones on my way home at Toyota. Upon looking at things the tees are still intact, but with a little pink crust on them, so I’ll change them anyway.
Since the tees were fine I decided to install the new battery we got for the Cruiser the other day, then take it for a spin around the block to see if it gets hot for me.....and it did.
Only drove maybe 1/2 mile and immediately started to see a quicker than normal rise in temp on Scangauge. I only let it get to 227* before I turned around, normal for our rig is about 190* in warm weather, it’s about 50* outside when I just drove it. Parked it, no codes thrown and then inspected engine bay for any leaks or abnormal stuff and the only thing that looks odd is there is a visible drip of water (coolant?) coming from a little stub of a hose coming from firewall on passenger side, dripping down onto the skid plate. It’s the hose pigtail adjacent the firewall heat shielding for the passenger side header. I thought this was a drain for the AC? I did hit the windshield defrost button on my test drive to unfog. Could it be coolant instead? Looked like water to me, no smell either.
Wondering what to check?
Some sort of blockage in the cooling system is what I’d guess next, like a stuck thermostat - which I’d assume was replaced in my tbelt service with the water pump at 190k from Toyota. I suppose I could pull it and test - I’ve gotta drain some coolant to do that, right? I just moved into a new house and it’s gravel driveway repairs until I build a shop in a few years.
Any other ideas before my in laws just decide to take it over to Toyota because I don’t have a lot of free time these days and it’s our kid hauler.
