Yah when I did my fan clutch it seem to spin about the same afterwards. But old made noise while free spinning and new was quiet and did slow rapidly. Also old was easier to spin by hand and would free spin for quite awhile as yours did even when warmed up. New would also free spin but only after spinning for awhile by hand with back force, even then only a turn or two. Mine old one made a noise that was most apparent after shutdown, as it free wheeled. I did not see overheating, but heard sound just as it started.
Stuck thermostat is very common cause of overheating. It may allow some coolant to pass just not enough. Blockage is not common in a properly maintained system where aftermarket coolant haven't been mixed in. Drain off a little coolant into clean container for reuse and check the thermostat. If ordering a new one, order new gasket also. I'd only go with OEM $20 well spent. I've been pulling and test latey and find all weak that I've checked over 150K miles, not check at earlier mileage.
Water pumps bushing going bad always yield a leak. Impeller failure I've not seen, but could happen I suppose.
On our 1998 Honda Odyssey with 390K miles, we (my ex) ended up warping the head after a blown rear hose but we got no coolant in the oil, we did end up with a higher coolant temp that caused overheating (ceased rings, main leak, coolant, etc).
I'm not much of a mechanic but I'm thinking that it's not viable to tear it down and rebuild the tired engine.
Your thoughts? Thanks in advance.
On the Odyssey I've not a clue.
Consider finding a low mileage used engine. Just make sure to check mileage with VIN, get a warranty and use a borescope if local or before labor of installing if not local. It's very possible long block is the same across different models and years, but less work to find match from same model.
The very best source is said to be a JDM engine. These are usually under 50K mile.
A complet rebuild can run the DIYer ~$3 to $4k in a V8 overhead cam engine. Plus tons of time, in addition to tools and FSM cost.
Some good suggestions on things to check later tonight, thanks.
When I did the test drive, the rig had only been off for about 2 hours before I got home. I did have heat in he cabin and I did grab the upper radiator hose to check, but not the lower one.
When I looked underneath at the skid pan it was bone dry except for the small puddle where that drip was coming from the firewall tube. Puddle about the size of a dollar bill, visible by looking down at skid past chassis on passenger side.
Coolant level in the radiator was up to the neck/overflow tube and looked normal, no milkshake, no bubbles. I could see the fins inside the radiator with my flashlight shined down into it.
I have the paperwork somewhere for the tbelt job and will look at the parts list to see if thermostat was replaced or not. I’d think if it was stuck there wouldn’t be any heat in the cabin at all?
Will also check the fan clutch. I did take note that with my head under the hood with it running, that she was like really really quiet running compared to my 22re truck I just tinkered with over the weekend. If the clutch on it works, it should kinda “roar”, right? Checking to see if the fan keeps spinning after shut down seems like an easy task. Is that all that’s needed to check it?
I never notice a "roar" but seem about right, but honestly never really looked for it. A bad fan clutch will often make a noise, kind of like the idler or tensioner bearing when going bad.
I would not expect condensation from AC unless AC is used. Are you using a AC or is compressor stuck on. Make sure all is normal here.
As far as cabin heat, I've not really thought about. See diagram above. Cabin heat should blow "very hot", with engine at normal operating temp and proper flow.
