Denso fuel pump pigtail part number
ceylonfj40nut
Waiting for Barn Time
TX
Tried the search. Not obvious. Does anyone have the part number or source where I can get the 2 pin male connector/ pigtail that plugs into OEM denso fuel pump? It’s for a 1997 fzj80. PO used a walbro spade connector that uses larger spade connectors which does not make a good connection to a denso pump.
I bet the part number is in here:
I have that resource. It did not seem to be listed.
Bummer! Found the pump on the schematic but it lists a 6-pin connector but I see that is the main connector, not the sub-one inside the tank. hmm.
The OEM fuel pump is/was made by AISAN.
Edit: see below
Photo showing an original connector (new fuel pump bracket), only # visible is E14 :
Edit: swapped for a photo of the actual connector on my spare (new) fuel pump bracket.
Looks like this
I don’t think the connector is provided as a spare part. Originally its part of the fuel bracket:
i can make more detailed photos after the weekend:
Thanks for sharing. The connector on the Belanger Motorsport site is for the Walbro pumps with larger spade pins which do not create good connection with the denso pump’s small pins. PO on my truck had a walbro installed and had spliced a walbro style connector. I am replacing it with a denso. It plugged in well but It was working intermittently until I figured it out.
@ceylonfj40nut : do you know the part number of the photo posted above? Only number on the connector of a new pump bracket I can find is E14, not the usual 5 digit number.
Other options: rob a connector from a used fuel pump bracket or buy a new fuel pump bracket while they're still available??
Here are some more close up photos of the original connector for future reference:
Width:
Space between the female terminals:
Length:
CD - I have a spare used connector locally if you need one ASAP.
I have not been able to find an individual part number for that connector. I have been able to find a Denso fuel pump kit that includes it though:
Deso 950-0226. Solid pump option from the 4R 2UZ. Includes connector, crimps, hose, strainer, crimps, etc
