Delta VS Radius Arms
I don’t get why the arms are made in multiple pieces, unless you don’t have machinery capable of cutting anything thicker.
We made a radius arm out of 3/4” plate for my buddy’s truck and it’s been fine. Similar to the Superior Engineering arms, we just welded bushing cups straight to it. It’s been a champ.
We figured it if ever gave us problems we would use some 1/8th or something and I-beam it. It’s been on the truck for three year with no issues.
Come to think of it, the arm might have just been 1/2” plate. I don’t remember.
Ok, please do. As @baldilocks noted, wheels forward is the worst it can get (steering components move up as they get closer to steering limits), so as long as it's not interfering (if you can turn by hand it's not interfering), you should be fine.
Looking at this, need the info from @Chrisw023 to see where things are and determine exactly why he's having a potential issue.
TO EVERYBODY READING THIS, DO NOT GRIND. The way these are made, that will cause issues, I will post pics in a bit that show why.
What about welding over the area that was ground down? Or, boring and appropriate number of fastener holes through the arm beneath the reworked area and apply a clamping force with grade 8 bolts? Are these arms not over engineered enough to allow for some material removal to ensure no tie rod/arm interference?
Seeing this situation is there a 3.0 version that may correct any bar contact? And by looking at his shocks the longest it could be are L’s (OME), and they’re are so many longer shocks on the market now that will definitely cause contact if the L’s barely hit.
A “high-clearance” version is definitely something we are looking into but we need more info on the setups that are like this to move forward with that, but please keep in mind longer shocks aren’t going to change anything. The axle, steering linkage, and radius arms are fixed in relation to one another, no matter how long shocks are.
Sorry long day at work and decided to wash the mud off the cruiser when i got home. Measuring from level ground to center bolt hole on each panhard bolt and subtracting the difference i am right at 4.5" difference. It's good to hear that my circumstance would have produced the least amount of clearance though the thicker bars like marlin crawler or slee's would make things that much worse still. Would a longer shock make the issue that much worse? Was originally thinking about upgrading to the dobinsons tapered springs front and rear once i get a little weight on the vehicle and their 6" shocks in front, currently run their 4" all the way around. I know baldilocks run them on the front.
Thanks for the measurement. No, longer shocks won’t change anything. Can you take some pics from all around your front suspension and email to dave@deltavs.com please? On flat ground for now, front of axles, etc.
I’m not sure what there is to get. These arms are designed for ease of repeatable manufacture, at a price point low enough that folks can benefit from them (which is working becuase we can’t keep them in stock). Fab time is pretty darn low, and there are multiple configurations that need to get dealt with.
A single 1/2” plate arm would be nowhere near strong enough for a product that is sold (might work for “your buddy’s rig”, but not a customer), 3/4” plate is difficult to process and limits the number of vendors we can work with and the timeframes we need (it could be ordered from an out of state laser shop, etc, but that adds a lot of lead time and potential for mistakes, which sucks).
If somebody wants to be able to return them, not a good idea to modify them. If you are capable of grinding them, re-welding them, and then re-coating them so they don’t corrode, and aren’t worried about returning them for any reason, then by all means, modify to your hearts content.
And no, they are not over-engineered to allow grinding and reshaping. They are designed to be used as is, and on all the rigs we’ve put them on, there is considerable clearance which is why more pics of your setup and now @Chrisw023’s setup are all of a sudden higher on the list of things we need.
@Delta VS, bushing deflection allows the arms and tie rod to move closer together and the farther the shocks will allow for down travel, the greater the deflection.
Valid point
Edit: not enough to be an issue on any of the installs we’ve done, which is what is so puzzling about these couple that are like this
I got miles of clearance on the 70 and tie rod but very very little clearance on the pinion.
Totally worthless info I know @Delta VS since it is custom but hey I am good at posting worthless info!
Cheers
@Delta VS , I know that we have spoken exstensively and I have responded to your requests for my specific info but, is there any other info I can provide?
I think we are plenty good on your front, I will reach out if need anything more. Thank you.
Few things:
1. after much debate, we have decided to ADD a "High Clearance" option to the radius arms. More details on that as they are available.
2. The pic below shows 2 of the 3 pieces (the one on the ground is used on each side) each arm consists of:
3. Haven't really mentioned it before, but those of you with 93/94 know about it. There is an ABS wiring harness that goes down the left radius arm that needs to bolt to the arm. We have a special version for that (you have to choose year when ordering on the site, that's how we determine), see tab and extra threaded hole below:
I’m interested.
Wait, wait, wait, did the vendor just respond to a "need" in such a quick manner? Surely, you jest. Don't call me Shirley.....
Nice job Delta
Nice job Delta
We like supporting this community in any way we can. That starts with quality parts that meet a need. If we can't provide that, we are doing something wrong.
That means you have $$$$ on the backside to deal (read: lose money) with cheap Land Cruiser losers. Good on you.
We just skip lunch is all, and every other dinner.
