Holy crap
More info?
Looks like the damaged diff was recently opened. I see the red gear lash "paint" on your ring gear they use to check for teeth contact pattern when setting up the diff. What's up with that?? Someone may have set things up improperly or not gotten something else right?
DougM
I just got an aussie locker for the rear third I bought..could spare the carrier if you are really wanting to use a used set...not the best idea. The aussie was cheap and will be a good improvement.
Bring e'm to Vegas !.....DustyHey Dusty,
If you look closely, you can see that one of the gears has a chip in one of the teeth. You probably don't want to put it back together like that.
Glad I could help,
T.
DougM
I would put used spiders back in that rig in a second..
Dusty, you haven't had that diff apart before have you?? You didn't say anything about it before..
Check your PMsBring e'm to Vegas !.....Dusty
I don't know if I will have everything apart by Vegas. Will have a stock ring and pinion, carrier, spiders, etc...essentially the guts of stock non-locker third. I am swapping in my 4.88s and an aussie locker so everything will be spare.
If I do get it done I will bring it to Vegas, and you will get a hella good deal![]()
Dusty if Dan doesn't have em I'll try to check later today but I might have mine at home. Will have to dig through some stuff and take a look but they might still be there.
