Dead Spiders !
Yeah dusty. we can do the swap :)
Looks like the damaged diff was recently opened. I see the red gear lash "paint" on your ring gear they use to check for teeth contact pattern when setting up the diff. What's up with that?? Someone may have set things up improperly or not gotten something else right?
DougM
Brother Brian's had the same paint, didn't show any signs of being apart, I was thinking it's factory paint?
Ya know, the more I see of you in here the more I feel my twitch that I thought was cured coming back and becoming a problem. :flipoff2:
Funny, it is feeling kinda homey around here.. I think I might stay a while :D
And Doug, it would be really hard to set up a ring and pinion pattern bad enough that the spiders saw the only damage ;)
I had this same thing happen on a 79 FJ40 except it hapened in the driveway! tuurning on pavement..unknown mileage...
Lucky Nothing ever happens in my driveway !
But my experance is in a landcruiser , it will get you home so you can work on it in the Driveway :grinpimp:
....Dusty​
DougM
The red paint is oem Toyota and likely there from factory setup. you will see this on toyotas of any age. Spider gears are pretty basic, you cant really set them up incorrectly anyhow. Running used spider gears would be fine as long as the bores in your carrier good still. I dont have any used ones right now. Other option is to install a traction aiding device whether locker, lsd, etc.
Anyone care to elaborate on what exactly happened here? I haven't seen this here before. Is this something that can happen under hard climbing conditions? The first picture doesn't look like to tuff of an obsticle.
Thanks,
Rookie2
Rookie2
Anyone care to elaborate on what exactly happened here? I haven't seen this here before. Is this something that can happen under hard climbing conditions? The first picture doesn't look like to tuff of an obstacle.
Thanks,
Rookie2
X2
One of my test engineers here says, by looking at what he can see in the pics provided, this was simply a torque failure, meaning most, if not all the torque was going through one side of the diff. Also, he thought this looked like "a clutch was dropped" which doesn't exist in our 80s, seeing as we all have slushboxes.
So what REALLY happened? :confused:
X2
Don't know if this is the same thing, but I have heard people (Slee I believe) talk about the e-locked rears having a "dog clutch" which will drop down when you remove the axle shafts (unless the diff is locked) from the rear axle, making it very difficult to get the shaft back in.
:beer:
Rookie2
Rookie2
He meant a sudden application of full torque to one wheel only...
Sorry for the lack of clarity.
Thanks,
Rookie2
It was too tuff for open differentials, the two FJC that were with me had to use there lockers .
What you can't see was the two Tire size boulders :doh: I was up on Left Font and right rear I was in low lock I have open Differentials with 285 X 16" BFG and 3" ARB lift .....Dusty 66
Don't know how it happened in this incident. But on automatics it's usually from wheel hop combined with generous application of throttle.
Interesting. Good to know for us unlocked boys.
So how'd you proceed from there... I.E. get her home?
Drove it home very carefully less than 20 miles, specially around the turns and easy on the gas !
