Damage assessment?
Just got a call from the local Toyota dealer: AC parts are in.
@UnderDawg is working on my new bumper.
OME J springs with 3 degree bushings are in custody of FedEx on the way to my door.
Just talked to Slee and they are shipping out a pair of used 863 springs with an OME steering damper - on their way tomorrow.
The lift application may take a bit as I only have about $200 left in my budget and still need shocks. Also the CS rep I talked to at Slee (Brett?) suggested that I will really need bump stops, and panhard rods for the front at a minimum to feel happy with the ride characteristics of the J spring... (at least that's what I understood from the conversation - I might have misunderstood as my technical knowledge is very limited)
YMMMV but with my J lift (4 corners) and running 2" MT spacers in the front I needed to go back to stock bushing and plates VS the 3* bushings I had in there. I have not done my bump stops yet. I think more importantly you may need to look at extended your brake and breather lines.
Call me on this I'll give you some honest and free info.
Yes running J's and a 2" spacer is like adding another 50% lift to the front. i.e. 4" spring/2" spacer. Going from a Heavy front spring to a J front spring is only 20mm so just over 3/4" people have been running heavies and OME 2 degree caster bushings for ever. Going to J's and 3 degree caster bushings is a good idea. If you are going above J's then yes I agree with you to keep the stock bushings and do plates, but they are also more work. For someone just looking to run 315's run the J's, do the slight bump stop and you will be set.
Going a different direction with my front bumper than previously planned.
Apparently DC Fabrications is 20% off all 80 series product during December.
Liking the look of their Outback Style winch bumper.
http://store.dcfabrication.com/products/fj80-outback-front-bumper
QzEzM0EzMEE2ODkyNkRDNjA4N0M6MTIxMTM3MDNhZmUwZGU3MzAwZTIwYWJmNDhiYjViN2I6Ojo6OjA=
It's this or an IronMan Deluxe
best price I can find is at Sierra Expeditions.
Ironman bumper is on, wiring up the lights and winch next then the lift kit that I put together from the classifieds here on MUD. Pics to follow. All this wiring has me thinking of a dual battery set up sooner rather than later. Found a '91 FJ80 in a salvage yard close by, hoping they have the battery tray. Is there anything else unique to the FJ80 for use on my '97 FZJ80? Given the dearth of Land Cruiser's around, much less in salvage yards I don't want to miss anything that might be important in the future as this one is surprisingly close.
Ironman has a bumper mounting bracket/winch plate that mounts up onto the frame horns first, made it nice and easy to fit together rather than muscle a full bumper with winch up onto the frame.
Bottle jack and cam straps to some cinder blocks to get it centered.
Found a '91 FJ80 in a salvage yard. Still had it's battery tray, so one piece closer to a dual battery set-up. Can't beat $10 even if I have to pay retail for the j bolts and battery bar it's more than enough savings to cover a washer bottle relocation kit from Slee. Although I'm trying to sort if I can do that on my own.
On another point; What's the consensus on using an aluminum or poly fairlead instead of this clunky roller fairlead with a steel cabled winch?
Probably not a good idea. I have a steel hawse fairlead on the Ramsey, and you can see the wire rope cutting into that one on occasion. I wouldn't think aluminum or poly would do well against the steel cable.
Ah... I was going to suggest you grab the AC lines and drier out of the 91 to relocate it up by your battery. Takes a little custom work for the lines but it tucks everything away nicely.
Also, it's worth grabbing the CDL switch if it's still there. I grab em and sell em on here for cheap to help 93/94 owners out.
It's close by, I can make another run out. Drier is decently protected by the new bumper, but I'll take a look.Thanks!
FWIW the wreck is tagged with 'runs on charging pack'.
Ahh, steel hawse fairlead, that makes more sense. Warn vs others?
Picked up some fabric manual seats from a 93 to replace my blown up driver's seat in leather with no recline function.
But this wire confused me a bit.
Seat belt sensor?
That's all I can really think it might be.
Lift finally going on, hopefully before the first of the year.
Picked up an Aussie locker for the rear. Good price so I hope to get that installed too.
