Damage assessment?
Question about driveability:
Small fender bender with my 80: bent in the driver's side front bumper, tore the plastc cap and something was hissing, dripping clear, petroleum smelling, viscous fluid.
Doesn't smell like coolant. Didn't overheat or even show an uptick in temp driving uphill about 3 miles at 40mph
Safe to drive until I can get it to claims adjuster?
The aluminum can behind the bumper cap that is missing is part of the a/c system ( receiver/dryer ) prob cracked a tube that leads into it and that is what was hissing..... Your a/c will no longer work due to having low/no pressure....
When the bumper is pushed back, it guillotines the line(s) off of the receiver/dryer. Most likely it was leaking freon/oil.
Thanks guys, into the adjuster in the next day I hope, fingers crossed for a cash payout enough to fix the dryer lines and upgrade the bumper...
That being said: the only real mechanical issue is the AC repair and all the other parts/paint/labor are inconsequential in the context of a new upgraded bumper so I plan on rolling all that into mods/upgrades.
I'm pretty much a :banana: mechanic... somehow things never work out how I would expect as can be attested by @atomicshawn who was nice enough to help me with an oil pressure question the other day. I only half joke when I tell people that my time for any given job is at least the book time ..... in days. With that in mind how likely is it that I can save an estimated $100 - $150 by redoing the lines/drier myself and only pay for the evacuate/recover/recharge? Every penny I don't spend on repairing character building minor dings or labor to a mechanic is a penny I get to spend on fun stuff.
Sounds pretty high.. What do they need 7 hours to do??
I glanced at your other posts, but why not just fix what needs to be fixed and spend the extra dough on an aftermarket bumper? Win win.. (kind of)
I bought those lines new from toyota. They were pretty cheap. You will need a new dryer now that has been open to the air. Buy an aftermarket bumper fix the ac call it good. Don't let someone rob you to do that work.
I'm certainly not going to complain about a high payout :D. Fix the AC unit and spend the rest on aftermarket is the exact plan.
Parts estimate $742 but only about $185 is the AC lines and drier. The rest is bumper, brackets, end caps etc. The remaining $1100 is body labor, paint labor and mechanical labor (that's the estimated labor for line/drier install, recovery, evacuate and recharge). In all honesty if I did all the paint and body they are recommending my front fender and front driver's flare would look way better than the rest of the vehicle. Based on all the breakdown I think I save myself about a $100 on mechanical labor if I do the AC myself and just take it in for recovery before and evacuate and recharge after.
Thanks, was wondering if I really needed a new drier or not as the bumper seems to have just taken out the lines.
@JasHook you ready to get modulated? Let me know brother.
UnderDawg modular front bumper on the way.
Estimate for dryer and the line that was damaged (parts only and I replace them myself) along with evacuate and recharge by my mechanic looks to be about $225.
This leaves money in the bank for improvements, thinking I might be able to squeeze a lift kit out of this if I can scrap one together on the MUD classifieds.
So far I can put together an OME front J spring with 3 degree caster correction bushings, a pair of OME front shocks and OME medium rear springs. Most people pair the J spring with a heavy rear though otherwise I'm going to have 'sag' in the back? Should I hold out for regular OME heavy springs in the front vs a 15mm spacer for the rear (is that a reasonable thing to do or am I screwing up the ride characteristics)?
I know I would still need to source a steering damper and rear shocks.
The build plan is front bumper with a 10K winch and 2nd battery eventually (sooner hopefully) Probably only end up doing a swing down rear for now. I just don't see the budget sustaining a full rear bumper with swing-outs anytime in the next couple of years.
A Wheelskins cover for my worn bare steering wheel and some new floor mats will put me pretty much where I want to be for now.
Here's to turning lemons into lemonade, eh?:clap:
Jas I'll have a swing down carrier for you sooner than later bud. I bought some more pieces parts for it today at the steel yard. I need to order a latch of some kind. Will be the best and most rugged I can find. Hang in there brohemis.
Just got a call from the local Toyota dealer: AC parts are in.
@UnderDawg is working on my new bumper.
OME J springs with 3 degree bushings are in custody of FedEx on the way to my door.
Just talked to Slee and they are shipping out a pair of used 863 springs with an OME steering damper - on their way tomorrow.
The lift application may take a bit as I only have about $200 left in my budget and still need shocks. Also the CS rep I talked to at Slee (Brett?) suggested that I will really need bump stops, and panhard rods for the front at a minimum to feel happy with the ride characteristics of the J spring... (at least that's what I understood from the conversation - I might have misunderstood as my technical knowledge is very limited)
