Daily Driver
Greenville, SC
Looking at getting a '96 Land Cruiser and was hoping to use it as my daily driver. Is this something that you would recommend? How much maintenance/upkeep is needed to be able to do this? I appreciate any help/insight you can provide.
loaded question.
do you own wrenches, or rent them?
how many will you be driving it?
how many miles are on it?
do you know the average mpg of an 80 series?
i daily a 93 with 220k at about 20k a year. company puts gas in it. i own my wrenches.
loaded question.
do you own wrenches, or rent them? Own, and father-in-law has 2 lifts and lots of tools.
how many will you be driving it? Might put 10k/year.
how many miles are on it? 200k
do you know the average mpg of an 80 series? I have read 10-12 is optimistic. I get paid mileage at work, so that isn't too big of a deal.
How many miles does it have?
When I got my 94 at 208,000 mi I replaced:
all wheel bearings,
tie rod ends
U-joints (not needed)
bearing front diff (really not needed)
water pump
ALL coolant hoses (I waited on PHH as it was not note at that time on forums)
valve cover gasket
spark plug gaskets
spark plugs
rotor cap
plug wires
all fluids
new birfields (Newfields)
front rear main seals
check valve clearance
remove and clean intake plenum
new egr modulator and VSV (when you get egr code)
O2's
steering bearings
thermostat
oil pump seal
oil pump regulator thingie in oil pump (forgot name)
sun roof drains
hood and rear hatch shocks
shocks
lift kit (not needed)
sliders (not needed)
arb bumper (not needed)
t-case (my fault, not needed
Common repairs: (X= number of times replaced repaired)
Radiator x2
birfield x2
O2's x2 (would be x3 but I leaned how to clean them)
shocks (would be x3 by now but I like worn shocks)
head gasket (I haven't had to do it yet)
repack bearings (many)
tune up (many)
oil chang (many)
miles per tank (250 to 275)
gas up at $80+ for tank of gas (tooooo many)!!!!!!!!!!!
I am at 436,000 mi and its been mostly problem free for almost 230,000 mi that I have put on it. Its a daily driver for me. (about 500 mi a week)
If you fix as many preventative maintenance things like I did, an FZJ80 can be mostly problem free, at least it has been for me.
If you are one to wait and fix as needed, it could give you the "nickle and dime" feeling.
Do a real good pre inspection before you buy one.
Have the head gasket checked with a chemical tester before you buy one (save you lots of $$$$)
Picked up my 97 TLC back in 07 to use as my primary daily driver :)
Got her with 81,xxx miles and she currently has 405,xxx, so yes, she gets driven :rolleyes:
I've only had to do regular maintenance and up until last month when I burnt an exhaust valve (my fault for not replacing valve seals when I should have), I've never had to do any major repairs :doh:
Here's a long ongoing thread from the day I took ownership documenting just about everything I've done so far.....
Finally got my new daily beater today!! (Edit: Train Horns FTW!!)
Only real complaint (apart from not having enough cup holders) is of course fuel consumption, but there's no other vehicle I'd rather drive on a daily basis :smokin:
I have daily drove mine for ten years. The only reason I have not driven it to work is when its being modified or the time I had to do a head gasket. I have other cars to drive, they are all newer and get better mileage I just like the 80.
How does not replacing valve seals cause a burnt valve?
How do you know when you have a burnt valve?
In my case, the bad valve seals caused excessive carbon buildup from all the oil passing through, which eventually caused the valve to stick and not close properly.
In the days prior to burning the valve, I got a random miss fire during cold starts (when valves are at their stickiest) that would go away after warming up.
Then one day, the miss fire remained.
After doing a compression test, I found 155 across the board except for cyl #2.
And after doing a leak down test, found out that it was either a stuck or burnt exhaust valve :(
Pulled the head and sure enough one of the exhaust valves had a small chip burned off of the edge :eek:
Unless you live down the trail of inaccessibility, an 80 is a terrible choice for a daily driver. They gobble gas, they need specialized maintenance, parts aren't common (but they are available), and they handle like the Exxon Valdez in the hands of Hazlewood. That being said, I love mine and often find myself driving it to work when I have arbitrarily better cars to drive. There's a knowing glance from those in the know that your leather and running board truck is the better choice than an "Zombie Response Team" JK for any situation short of rock crawling.
Unless you have detailed service records addressing the known issues (axle seals, headgasket, PHH, EGR, CEL stuck on), prepare to double your initial outlay to make the truck "right". At 10-12 mpg around town, horrid to marginal braking (depending in the 91-92 or 93+ design) and the acceleration on par with a Korean econobox, prepare to adjust your driving style and wallet opening behaviors.
I find the opposite to be true. At low speeds they are absolutely brilliant. They pirouette, like a ballerina, despite their size. At higher speeds, they are one of the best handling of the larger SUVs.
I may amend my statement once the new OME stock height springs and new Tokico OEM shocks are installed along with new front control arm bushings. As it stands, it's a 22 year old truck that handles a lot like...a 22 year old truck with a worn suspension and cheap previous owner Monroe shocks. I've driven far, far worse, most of them painted green or tan with an "M-series" designation.
Only you know the answer, but if it if is just to get yourself to work and back, probably not. These trucks are best left to off-road/ expedition type stuff. Fuel mileage is crap, and getting a 20 yr vehicle into a good state of repair can be expensive just to drive to work and back, but as others have said there is something about sitting in one of these that always puts a smile on your face.;)
I think the biggest thing is if you work on your own vehicle. If you do and can do modifications, it might be a good choice.
If you like the safety of a tank, get an 80 or a MK3 Supra (its a tank too).
With the proper air pressure in tires, new springs & shocks along with replacing worn bushings front and rear and making sure the sway bar mount is not broken, they can handle quite well. I found low tire pressure makes the 80 feel mushy and handles poorly. I run 45 to 66 psi depending on the tire design.
Braking is fixed by removing the ABS unit and installing a proportioning valve.
Gas mileage sucks but longevity is a plus. My motor is starting to (is) show signs or needed rebuilt but it still runs hard at 436,000 mi.
To me the 80 is my choice for year round daily driver for all weather conditions and in dangerous driving conditions (Debeque Canyon falling rocks and Denver traffic). If I had to get another daily computer it would be a MK3 Supra again (fun but sucks in snow).
with as many as you see with 200-300- and 400k miles on them I think that means they have to be pretty damn good daily drivers right?
People get all crazy with early maintenance and "finding the best truck" and then spending 3k dollars on maintenance parts any way. Then they do 3k mile oil changes and all that "cheap insurance" while also pointing out these trucks are all over the world with 400k miles on them and never get maintained.
I wanted one as a daily driver. Did some research and new what to look for. Bought my 97 with 141000 miles on it and I am at 153000 now in just a few months. And maybe spent a few hundred dollars on egr stuff.
I will never be in the "just change the radiator because its old" group, and would never tell someone that they shouldn't if that's what they feel comfortable with.
If you are mechanically inclined just look your truck over weekly [is what I do gets e out of the house a bit :)] and if the truck has an issue or you see when coming up take care of it.
I bought the truck because the reliability is legendary, not because it needs to be taken care of like a super car.
In terms of being a reliable daily driver and "what could go wrong" I think this 20 year old suv has my 2007 twin turbo bmw with 85k miles on it beat by a mile...now braking and acceleration....that's a different story haha
Plus, it helps if your backup vehicle is stone cold sex on wheels....
If you are going to daily drive ANY 20 year old vehicle, you really need to have two of them.
That way you aren't stranded with normal maintenance items.
Much could be said about new cars too. When I am getting oil filter from local Toyota dealer, their shop is always overflowing with broken down "New" cars. Lately its been a 2 week wait to just get your car in to get checked out, longer if they have to order parts.
