Damn !! Really nice job on the write up and final result. I didn’t realize you could run D2S quads in Depos until reading your thread. Time to go back and load another set of D2’s in my setup. Thank!!
For the top clip simply turn the adjusting bolt until it releases. The second one requires you to pinch the clip with needle nose pliers and pull the reflector out.Finally found time to work on my DEPO project but ran into a few challenges. Resurfacing this thread in case anyone else plans to upgrade the 20+ y/o headlights. I've removed the glass thanks to everyone's help, it was a lot easier than I thought! I'm attempting to install D2S and want to remove the housing to paint and also shave down a few areas to buy some clearance for the projector. (Trying to be like @Luke111 but only half as cool cause I'm not doing quads)
What is the best way to remove the white tabs circled? One of them looks like a clip that might just need the right angle and the other is the adjuster. Anyone have any pointers?
View attachment 2566346View attachment 2566347
I'm not running quad D2S's... the inside projectors are smallerDamn !! Really nice job on the write up and final result. I didn’t realize you could run D2S quads in Depos until reading your thread. Time to go back and load another set of D2’s in my setup. Thank!!
There's nothing like a great set of headlights that you use all the timeI might be ok with a good fit then, but I really don't need another project.
You should always install and make all your adjustments before sealing the lights. You need to make sure your cutoff is level then adjust height.. What adjustments are you having issues with?This thread is great, thanks for the tips @Luke111.
Unfortunately, I discovered I don’t have enough adjustment room with the D2S’s AFTER sealing them up
I’ll have to do this over the weekend
Rotating the projector after you’ve sealed the light would require you to turn it from the back of the housing. …. not sure that’s even possible. Mount the lights unsealed allows you to turn them from the front. After making your adjustments remove the lights and use a liberal amount of JB Weld on the locking ring and the back of the projector tying it into the back of the reflector bowl.
Did you sand down the back of the reflector giving you a level base for the locking ring?
This is important that it’s level and on the same plane as the front on the reflector bowl. If it’s not on plane the projector will be slightly angled limiting the adjustment. I’m assuming you removed the reflector bowl. Did you make sure you recounted it to the snap ball at the top? If not this will greatly limit your adjustment and lastly if the projector is hitting the glass did you follow what I did the create room? Take your time and feel free to call me if you have any questions. 703-371-8494
Lou
Did you buy the shims from a specific site?
not sure I saw it in the thread anywhere but what are the two different setups in these? when I google mini h1 I see the projector and when google d2s only bulbs come up. do you sell everything on your site to do this? thanks. super happy with my parts from you for the 470.
The Retrofit Source is a great source for product but I would stick with the Mini H1 for your first retrofit. Try searching Mini D2S 5.0 projector.not sure I saw it in the thread anywhere but what are the two different setups in these? when I google mini h1 I see the projector and when google d2s only bulbs come up. do you sell everything on your site to do this? thanks. super happy with my parts from you for the 470.
Ok. Is that the inner or outer one in this thread? As mentioned I got the plates and full kit from you for my 470 and it’s been great. I hate the look of these on an 80 but the light output is so amazing on the 470 I’m willing to do them on the 80.The Retrofit Source is a great source for product but I would stick with the Mini H1 for your first retrofit. Try searching Mini D2S 5.0 projector.
The mini h1 is the inner one/high-beam. The micro d2s 5.0 bi-xenon is the same dimensions as the mini h1 but has low/high beam function.Ok. Is that the inner or outer one in this thread? As mentioned I got the plates and full kit from you for my 470 and it’s been great. I hate the look of these on an 80 but the light output is so amazing on the 470 I’m willing to do them on the 80.
No, the inner projector in my setup is not a Mini H1. @swankstar, if you have time give me a call for a more fluid discussion regarding the different setupsThe mini h1 is the inner one/high-beam. The micro d2s 5.0 bi-xenon is the same dimensions as the mini h1 but has low/high beam function.
After reading the other thread on hard mounting the pivot point I now see what projector you used for the high beam side. Please disregard, it was confusing.No, the inner projector in my setup is not a Mini H1. @swankstar, if you have time give me a call for a more fluid discussion regarding the different setups
703-371-8494
Lou
I don't remember but the H1 2.0 are pretty small. I'm currently working on a new setup for the 80 using a Micro D2S and the Profile High Beam LED. I think quad HID are over kill , much harder to get four cutoff's aligned and you are not really gaining much more output. If you're looking for greater distance add a pair of Morimoto 4 Banger spot pattern POD's on your bumper and only the HXB version which produce an absolutely absurd amount of light and distance.After reading the other thread on hard mounting the pivot point I now see what projector you used for the high beam side. Please disregard, it was confusing.
After modifying the high beam pivot point and installing your Lightwerks micro h1 2.0, approximately how much space did you have from the projector to the glass front housing? I'm looking into tackling a quad setup but going with x4 Morimoto bixenon micro d2s 5.0s for symmetry.
