I am just finishing up a head gasket replacement on my 96. Engine is misfiring on cylinder 1 and I can’t figure out why. Swapped plug and wire to different cylinder and it’s the same misfire at #1. I installed a new pressure reg. And had all injectors cleaned and flow tested at the injector shop. Timing is at 3 degrees. I’ve got running compression on #1 of around 90psi at idle. Any ideas?? Thanks in advance!
