CXRacing Performance Header.
Not that I would ever recommend their product/service but technically JET Performance Products offers a service to reprogram the Land Cruiser ECU.
I see no reason whatsoever to go with a header on the 1fze. After taking mine apart and sending it to be ceramic coated it came out very nice. Plus the fittment and OEM gasket go together very easily compared to earlier model F and 2f engines. I was overall very impressed by the engineering on our motors.
Haha I challenge you to find anyone that has actually done the JET reprogram. If you look at JET's list it is every single car. I guarantee you they don't have anything for the 1FZFE. At the very most they will be using you as a guinea pig.
I;ve got them on my truck, no huge issues. Butt dyne says I get a little more torque. The only little things i had to do was cut off the part that turns up after the resonator on the CXRacing piece and weld a flange onto the resonator. I eliminated the first cat and bolted directly to the second cat. If your truck is older you may need to do engine mounts, mine has 207k and was sagging a few millimeters where the pipes knock the frame by the actual flex pipe. Other than that, no issues in the last 2.5 years of abuse
yea, whats with that flange turning up like that? stock from the cat is a straight flange...........
Ill get pics tomorrow, you cut off the turn up, weld a flange on, remove first cat and bolt up to second cat. The resonator it comes with is almost the same length as OEM cat...
94' obd1 (2 o2 sensors before the Y pipe) CX Racing Headers and down pipe installed.
Save your self a headache on this one. The headers are pretty solid, the down pipes are garbage. Buy the header, a couple 02 bungs from slee and get a decent exhaust shop to tie it all in. I've been trying to make mine fit for a year now.. finally got it put together and sealed up(ish).. and the flex pipes blew out and came to pieces. Ended up cutting all of it out and starting over. Just have everything after the header built up front and save yourself a couple cuss words.
