CX racing header and downpipe
It could be done that way, the downpipe points back up around the frame without a cat so I just picked it up from there. It only had one O2 sensor bung so we robbed one off my old ems exhaust and welded it into the new exhaust
Has anyone on here installed their turbo kit?
I haven't but I would be prepared for some additional work and marginal quality. I would strongly suggest checking out the turbo set up suggested by @scottryana . You'll have to do a search to find it but he knows his stuff and there will be no crappy parts. It will work with the factory computer and give great power and driveability. Whenever free time come into my life, that's what my other 80 is getting
The down pipe points back up to go over the frame so it might not be too bad. Be prepared to have to clean up the ports,,they're pretty scetchy. Good luck!
Even if I have to remake the S portion over the frame it won't bother me too much. It was my first foray into exhaust work and probably the worst vehicle to attempt it on, it could use some tweaks haha.
Already talked to a good buddy who is a magician with a tig. I will take a look and probably get him to build it up, then I can clearance away.
Kinda pumped to hopefully be done with this exhaust mess. I just need my garage back to do the work! Renos always get in the way ;)
Glad to see one of these installed - I recall the other header thread (truth told, the "hater" fella directed his interest at me when I stated support for the OP - was that you as OP then?)
Amazing the work it took - how would you describe the header tube quality - sidewall looks thick enough, did it seem like quality uniform tubing stainless?
With the coating (near required for Northern winter preservation) - are you recording any underhood temps - and are you planning to run a heat shield of some sort?
I ask on heat shield for the peeps with either a S/C or turbo planned & how most of it generally ends up over the exhaust ports.
The tube quality seems good, thick wall. I think the temp will be an issue and a heat shield needs to happen, it's very close to the supercharger. I haven't run the truck for more than a couple minutes so far. I'll post up more as I go
It's probably around 12 guage i would guess. Pretty beefy, but not that thick.
One thing on my mind about exhaust and headers is the use of stainless pipe. I'm not sure it's all its cracked up to be (pun intended). It has a problem with warpage due to heat and crack resistance due to fatigue than mild steel, at least I believe that is true. As far as corrosion resistance goes, the cheaper China stainless (which this is) seems to have rust issues anyway, like the EMS system does in the rust belt. These are just random observations but maybe some metallurgically superior minds could chime in so we all may learn something?
Nope very valid. The thermal expansion on stainless is also about 2-3 times that of mild steel. If you are going to have a very good coating applied to the manifold, mild is just fine and probably better. But the problem is that the coating needs to be very good to stand up to the high temp, and heat cycling.
X2 in the coating importance. Ceramic coating is great if done right, but it is usually pricey. I used to do it but gave it up because it was not really profitable
The window for success on the application is very small. The material is great, the application is a nightmare. Swain tech and Jet Hot have well developed processes so their reject rate is minimal
I think the guy who built yours got fired. This is the worst of all 6 on mine. Clean it up a bit for flow but all in all pretty clean.
The thing I was seeing was that they pretty much welded round tube to oval shaped flanges. I did get a reasonable transition eventually. Took my first drive today after head gasket, new header with 3" exhaust all the way out, ported supercharger and a bunch of other "while you are in there stuff". It's been 3 months, way too long. The new exhaust note is pretty sweet, a bit deeper than the EMS powered system, way less drone and a screaming rap when on it. I haven't stood on it hard till it runs a while though. I'll try to do an exhaust sound video tonight
Agreed, I was talking more about finish. It is more angled in than the picture shows but regardless will still cause some backup for sure. I am still going to grind it out a bit and clean it up.
