CX racing header and downpipe
dogfishlake
"Go on a living spree"
Supporting Vendor
greenville mi
Has anybody tried the 1fz-fe header with 3" downpipe from CX racing yet? It looks pretty nice. I have the ems powered exhaust now and it's gonna need some help around the y - pipe area directly and I'm thinking about integrating the CX set up. I have the kazuma sc and air to air intercooler so I'm thinking I may see a gain from the header. Anybody have thoughts on this? Thanks
Cool, thanks. I think so too but I wonder about the limits of the sc and the limits of the factory computer to adapt to the benefits of the exhaust. I can go smaller pulley easy enough
Do you have a link for it? I tried google but didn't find it
Go to cxracing.com and look under jdm. On the side is land cruiser lx 450 80 series. They have turbo kits and the header
Considering the corrosion failures with the ems system, it might be a good idea to add the cost of ceramic coating on this set up(at least for us rust belt people). Probably around $300 for ceramic, or see if your local powder coater can put 1200 degree silicone powder on it (should cost $100-150 bucks).
I've got it on my truck for maybe six months now, I like it, no complaints, fits good and routes good over the frame like the factory one. A little fab needed to make it fit on the factory setup. I removed the first cat and welded a flange to the cxracing.com resonator and bolted it to the second cat. The only little thing is with the bigger pipes, you have to move the passenger side brake line bracket off the truck frame and bend the hard line a little and re-mount. Been playing with some of my jeep buddies, no issues with the pipes. They've been hot and plugged in cold muddy water, banged around…no issues
Very good to hear. It would be nice to have a high performance exhaust option again
Hey pnguyen,
Do you have any pics of how you have your header setup? I'm talking with my local muffler shop bud and trying to get an idea of how to integrate the cx racing header/y pipe with a single cat. Sounds like that's what you did. Does it trigger codes? My other option is to pair up the cx racing header with the Magna-flow y pipe. Any thoughts?
Thanks in advance.
Hey pnguyen,
Thanks in advance.
I'll take some pics again, I've had no codes since the header install. Basically, you need to measure the resonator where it would mate with the second cat, cut the CX racing bend, weld a flange on, and thats it! I was thinking about doing the Magnaflow route also....
uu
Thanks @pnguyen
It looks great! I'm going to barrow your idea here. The OEM exhaust manifold has fairly good access... Was the header install a PITA? Do you remember approximately how many hours it took for the full job?
Thanks brother!
uu
Thanks @pnguyen
Thanks brother!
I hit the bolts with penetrating oil two days before the attempting to take off the manifold nuts. They came of without any effort, had them all off in about 15-20 mins. I was expecting to fight with broken and stripped nuts/bolts. Total install with welding took maybe 2-3hrs. No check engine light, maybe a little more torque.....but its better 100 times better than cracked factory Y-pipe.
O.k. so I hesitate to ask because this can of worms has been opened on other threads with disastrous result BUT, do you notice any difference in power with this set up? Dare I say, Butt dyno?
I think it added 45-85hp!! :steer:
I don't think it added any power, but in all honesty, I think i did gain little low end torque. There is a climb on a local trail that the pig struggles to climb. It may have been the cracked factory manifold and Y-pipe letting out all the horsepower, but after the CX headers, she climbs it with less drama
Works for me, thanks. I'm doing the head gasket pm so I will have the head off anyway and my factory manifolds have broken studs and cobble-ness. I've got a supercharger so I'm thinking it will help the total package. If I get one, I'll get pics
The CX header is the only current production one I know of. Anyone know/recommend any others?
Thank you for the info... My y-pipe has cracked and been welded a few times too many. It's about time I upgraded the Cat-up.
Just ordered my CX racing header. We will see how this goes
