CW 2.0
My trucks 6150 pounds and more with three passengers going threw a washout on an angle I will have one bump stops hard on each axle.
That weight alone all on only two tires the bumps would be more than 1500 pounds resting on the two stops.
That's probably over 2k more than my truck weighs, so not the same thing, but even so the dampening effect is the main point here.
The weight rating is just the number at which they'll keep doing it all day, at some point they won't rebound as much if you squish them further, but it's not like they'll get pancake thin if 1500 pounds is put on them.
Anyways I'm not worried. They make 3 variations, this is the lightest density, if I really wanted I could get heavier ones, but Jonathan's truck is closer to the weight of yours and he hasn't had any issues. :meh:
I'm on my second set of OME med on front that they claim 2" of lift. I've kept a pretty close eye on the distance from the
top of the Sumo to the frame. It's down about 1/2". Might seem weird but I suspend my springs when I go away, frame is
on jack stands so the tires are clear of the ground. Weird philosophy that they aren't sitting holding weight for 5-6 weeks.
I run OME shocks. Of all of us I run the largest tire, basically measure out at 34.5". Fully loaded if I run into a cross ditch I will
bottom out fronts and in a turn the top of the tire rubs the inner fender fairly well but despite polishing never done any damage.
Since it's been 40K since I installed them, I did not replace the knuckle bearings at that time, it's about 15K more on them. This
last diff swap and tire rotation I noticed the front tires wearing bad. So I'll be getting to the knuckle bearings soon. I'm curious cause
the sumo's have really stabilized the front, and my belief is they somewhat protect the knuckle from worst of the pounding. But
they are consumable, like the springs. So when they come out we'll see if they come out worn out, or come out in little bits of
hardened bearing pieces.
That’s exactly why I was wondering how do you set the height of these with all those variables to bottom out before the shocks or hangers do.
I guess it’s just an estimate and see thing.
I’m also on Ome mediums so I use my bump stops a lot. I have the longest shocks I could fit so in those cross ditch situations I can drop an axle a fair bit keeping tires down. But that limits my up travel to 2 1/2 inches ~ having a progressive bump stop appeals but only if these progressive bump stops range would work still allowing some up travel at the same time stopping it at the right point.
OME shocks are length limiting shocks and are designed as stops to prevent over extension of the springs.
They have internal stops. Confirmed by conversation with tech from OME.
Up travel is always limited and with my truck tires do the limiting, there are definitely
polished areas when I'm pushing it and being heavy it's an easy limit to reach.
Tired of arguing about bump stops and replacing deck beams, so I figured I'd do something easy that's been bugging me for years.
Several hours of sweat rage and skinned knuckles later, my front clip looks like it was aligned by someone vaguely sober.
Still not perfect but it's a hell of a lot better. Had to pull the fender supports and slot the bolt holes another half inch on both sides, and remove a shim from under the bib.
To fix this if have to adjust the hood hinges, but those bolts haven't been touched since new, and I don't feel like drilling them out.... because I know they'll all snap or strip.
(I just knocked out the pins to remove the hood before)
Also did this so the girly parts weren't showing under the dress. Laced on with zip ties for lack of a better idea.
Now. That's enough of this vaguely sober bull****...🤣🤣
Went for a long ride in it yesterday, wasn't thrilled with it. The blue things were just a bit too close out back and were making it bouncy.
To move them further away would be a lot of work, and if I'm going to do a lot of work it'll be to fit proper airbags. Which I kinda want to do anyway.
So. Back to the front.
Think I have them just about right. Couple inches away, and even if they contact they should be squishier with all the weight.
No, that is not a hockey puck underneath 🤣
Dunno if I'll leave the landing pad there. I'll think about that another day. It 🍻 time.
Curious why you gave up on the rears not enough cushion need to move mounts up a bit
Never have I heard of anything on a cruiser being called 'girly parts'! 🤣
...steering boxia, injection pumpulva, oil pan majora... ughhh.
Well, mainly because I'd have had to make new mounts that were a bit shorter.
Right now I have the stock 45 bumps, so they're probably cast, which would mean making totally new ones, can't just move them up a bit
Which is a fair bit of work.
And if I'm going that far, I kinda wanted to do airbags anyway at some point.
Suspension on this truck is a bunch of trial and error. Heavy on the error lol...but the rears are 70's half ton Chevy.
I also want to change the main leaves (or everything) before I do a bunch of work. For now, it rides nice, got pretty close for rummaging through a spring shops racks with a tape measure, I just hate the over long shackles.
Mulva. 🤣
So worst story ever, but I s*** you not the DAY after watching that Seinfeld episode, I went to the bank and my teller was named Bunt.
I almost died 😳🤣
View attachment 3976380View attachment 3976381
It wouldn't surprise me of some new 40s weren't much better than that when they rolled of the assembly line... they are essentially tractors after all. The finishing work on the hood spears wasn't exactly precision work. I wouldn't be surprised if the alignment of a Friday end of day truck might even be worse.
I suppose one of these days I should hack off the obsolete steering pedestal... and fab some front inner fenders. Probably fix the floors, door sills/rockers, rear 1/4s, and then last but not least inner fenders. It's looking like all the new sheet metal will be stainless.
I really hate filler, so my goal is to not use any. If things go well I may leave the stainless steel raw. See now it looks before making a final decision.
Yeah they're pretty crude. Like this example from my 60 floor pan. Factory triangular hole with a piece of tin gooped over it . Fine coachbuilding 🤣🤣
Bought a set of these things. Only 50 bucks or so, and definitely makes it easier. Should have bought or made something like it 25 years ago.
Doing knuckles on the 60 soon so I figgered ****it.
This is the vevor version. There's ones made of thicker steel that cost more, but it's not like you're using it as a pry bar. Might actually be stainless, not that it matters.
Can watch the measurements change as you turn the tie rod...kinda slick.
Just posting this here for when I lose the paperwork. I looked , but couldn't find a tie measurement in degrees for cruisers. I'm at about somewhere in the .32 to .4 degree range.
Have to take it for a burn to see how it drives. My precision tire measuring before was way off. 😳
I recently bought a set of those. Bought for a bit less from someone who was selling an unused set. They would be perfect for a 40. On the Ambo putting the front on axle stands changes the alignment a bit because of the independent suspension. With a bit of messing around I’m satisfied with the results. I can now release my tight grip on the steering wheel while driving and it goes in a straight line. Way better than the dealership alignment and it wasn’t $280. When it left the dealership it would quickly dart out of lane (f-ers). They wanted another $280 to finish the job they (f-d) up.
They work pretty damn well. Definitely easier than trying to measure off tires or rims.
I was pretty careful last time I did it and was off by an embarrassing amount ...bet I ****ed up the 60 too 😂
Never had a problem doing the old tread measuring. 1/4 for 33” and 1/2 for 35’s etc.
Although I’m pretty sure the bandeirante has zero caster.
I didn't either really , but this takes half the time and is more accurate, so there's no downside for me.
What this thing proved to me is how forgiving these old tractors are. I went from 3/16 toe out to 1/8 toe in and it doesn't drive noticeably different other than a shimmy at 85kph is gone. :meh:
Hahaha! Old brick tractors. 110%
Cruisers been doing it's best impersonation of an old dog with a dribbly pecker.
I tried a generic oil seal on the PTO output because I didn't want to wait a month for a real one at the time .
Yeah. Don't do that.
Generic vs Toyota...well over double the seal surface.
And part number.
Bought a spare because I suspect it's going to leak one I start using it.
Good to know!!!
So far the bandeirate is the first old dog without a dribbly dick I've ever owned!!
