Custom 3d Printed Overhead Consoles for 80 Series
Definitely interested in a gray one if you are still doing these. I'm thinking I would want a blank one and if not too hard to cut/drill I'll modify as needed. LMK what you think. Thanks!
Came across this via a fb post in the cruiser community. I’ll definitely be in touch!
Thanks @Ballsie, this thing is sweet!
Maybe I missed it, but are you able to do one for mounting a SwitchPros panel?
I had someone ask about that recently. I don't have a design, but I can design one for you if you want to send me your Switch Pro. I will send it back with your console.
My truck is currently in the shop getting an electrical system refresh and they'll be installing the SwitchPros. So they have the panel. But they're not mounting it in the cabin, just running the wiring through the firewall and leaving it loose until I decide where I want to mount the panel. I'll check in with the techs and see if they're done testing the system, and then I should be able to have them ship you the panel so you can design how to incorporate it into your overhead console.
Assuming I can get the panel shipped out to you by the end of the week, what rough timeline would you anticipate to get the console designed and printed?
Thanks. I really think your design is the best option for me, and I think it will be a popular option for those who are looking to install a switch pros like me in their 80.
Id say it will probably take 2-3 evenings after work to get a good design. We will take measurements, design one, and print it. Then we will probably need to make small changes and reprint it 2 or 3 times to get it perfect.
Let me know when you are ready to ship it.
Thanks!
Great. I think they'll have things wrapped up on the SwitchPros install by the end of the week. I'll be in touch.
It looks just like it but the mounting points are different.
Did you open the PDF file or just look at the main page pics? The panel is pretty much surface mount if you want or you can use their bracket that you can see the corner of in the main picture. Would you be interested in borrowing this panel to design a file/print to mount it? If not I may just order one that's blank and cut my own opening...which would actually just consist of drilling 4 small mounting holes for the machine screws to pass through and a bigger one for the wire and connector to pass through.
I sent you a PM
Just received and installed my custom overhead console from Ballsie today. He made it for a perfect fit with my Switch-Pros control panel. Really pleased!
Does anybody know if this will fit a 1991 hdj ? Mine does not have the bigger one with the gauges, just a small one with a map light and the sunroof switches.
I mean does the bigger one not need different mounting points ?
Never tried it with a 91 model. Send me a picture of your current console.
