Curb weight ....
las vegas
So I’ve been trying to figure out if my two aftermarket pieces on my rig were too heavy for her because they’re not namebrand rig pieces and I feel as if they are too heavy so I went to the gas station to weigh my truck today and it came out to 5 so I’ve been trying to figure out if my to aftermarket piece is on my rig were too heavy for her because they’re not namebrand rig pieces and I feel as if they’re too heavy so I went to the gas station to weigh my truck today and it came out to 5480 Now I did a little research and I noticed that my truck curb weight bone stock should be weighing around 2600 now I don’t know if my bumper weighs more than an actual brand-name bumper would if that’s why it was cheap I purchased a vehicle with this bumper and roof rack on it no brand name on any of it from what I can tell I feel as if my transmission is working too hard caring around this bumper and this roof rack I am wanting to get an ARB bumper because I feel as if they are later does anyone have to wait for them or know anything about this subject
Yes
well since youre trying to figure out if the bumper is too heavy weight it with it off the truck so you know how much it is then you can add it to the weight of the front of the truck and know how much it is when many people have built their own bumpers and used different materials there are really heavy bumpers with winches and lights on them that adds weight to the front of the truck but you can always add different springs to it that can compensate for the weight that you have measured in pounds not kilograms but if you read the picture it says pounds and kilograms so im not sure which one you are referring to for the curb weight of your truck since you did not use units in your question most of these trucks weigh in around 5000 pounds not kilograms but some peoples heavily loaded trucks are as heavy as 7000 pounds but im not sure what their break down is from front to rear for the balance weight if the truck feels like it is soft in the front then maybe its too heavy but you can install heavier springs overall its not too heavy though there are lots of folks here with more crap on your truck than you have
Not sure where you got your Curb weight from. But it is a little low.
Your truck is only about 300lbs heavier than a stock truck. Not too bad. Your bumper looks fine.
2600# uh you forgot the other half, I know mine is at #5700 with a Cummins and stock bumpers and a full tank of fuel
I saw it on google i tried looking it up guess it was wrong then
Is this the text that results when people dictate to their phone?
Well there are some lighter options, the bumper has all that stuff protecting the lights and grill, if you don't need that protection you could remove that and just have the lower bumper portion. Also your winch could switch to synthetic etc all would help drop some weight, however your rig looks pretty nice. For the back you could make sure that you remove factory roof rack if it is still under the aftermarket one, the ridge runners (they don't weigh much either) and you could get under the back and remove the brackets that once held the spare tire under the back bumper.. all those things add up a little here and there. Remove the center console sub.. that will help you drop at least a pound.
In AUS there are companies that make alloy bumpers.. they wont' have the beefiness of steal but they will be a lot lighter. Some are pretty strong when hit from certain angles I am sure.
I think you could also switch trannys to the h151f. I think it is quite a bit lighter.
Mind if I ask where you got the non-branded hardware? I always wonder what places are making bumpers for 80-series
Here is my cheat cheat
F bumper (ARB) + winch = ~160 lbs Factory F bumper = ~35 lbs
R bumper (Trail tailor) = ~135 lbs Factory R bumper + X member + hitch = ~120 lbs
Sliders (Trail tailor) = ~135 lbs Factory running boards = ~30 lbs
Roof rack (Bowfin) = ~ 60 lbs Factory roof rack = ~10 lbs
Creeper skid = ~35 lbs Factory tranny skid/ x member = ~15 lbs
Total = +/- 525 lbs Total = +/- 210 lbs
Net gain = +/- 315 lbs
Just needed to give Bilt4me another like!!:rofl:
My buddy out in Florida gets his hands on them and ships them around I’m not too sure i could
Give you his number. That roof rack was only $560 bucks 8 point mount with a mounted tire holder
