Cummins 4bt swap
Ancho, NM
I am looking to do a 4bt swap into my 98. I'm not worried about noise or vibration as I'm building for fuel economy. I have a source to fab all the parts needed. Does anyone out there have templates for adapter plates and mounts? Or is there an online source for this stuff? I'd like to try and get it done while I'm on vacation dowwn in Tucson and in the area of the shop. Thanks for any help!
Pretty sure you'd be the first in a 100. Post lots of pics!
how you going to register it? do you need to pass emissions?
sweet. everything I read on a diesel swap points to major coin. I looked into swapping a cummins into my F250 back in the day, and it was $30k plus a new engine to get it right.
I'd talk with the folks at Profitt's Cruisers, they several 4bt's into 60's and 80's, they may have done one into a 100 we just don't know about, or may have eyeballed it and know if it's possible.
There's an inmate that recently did a 6bt swap into his 80 series over in the diesel tech forum. You might post up there for some advice. He used an upfitter/diesel repower speciaist in Montana.
Swapping in a diesel (or any motor) for "fuel economy" doesn't seem to make much sense.
Let's make a few assumptions:
1. You're currently getting 14 mpg
2. You'll get 23 mpg with the new diesel
3. Gas costs $2.30/gal
4. Diesel costs $2.50/gal
5. You could pull this off for $5,000
You'd break even around the 90,000 mile mark. Now, if the current motor is toast, or the swap is for towing... or the cool factor, well disregard all rational justification and start a build thread!
Much of what I have read, people are claiming upwards of 30mpg for a 3.3. Im not worried about saving money on fuel, especially at the current prices. My main objective is to extend the range. Sometime in the near to somewhat near future I want to take my boys from Alaska to Chile and to don't want to ever stop to fill up, hahaha...beside, the cool factor is a close second and towing comes in third as that's what 3/4 ton pickups are for :)
I considered buying my (in mint condition 05 f250) back from a friend and swapping in the 5.9. The truck has 107k and is pristine and the injector went and trashed the motor. I can get it back for $8k and spend a quoted $18k for a shop who does them on a regular basis for guys in the oil field...it'd be worth it, considering what a new pickup costs these days, although I'd never get my money back if I sold it...the cruiser I'll do myself. I estimate I can come in under $5k.
I assume you are aware that Cummings is introducing a diesel crate motor to USA. Check expedition portal for a discussion on that.
Actually, no...until now I was ignorant to this ;) Does cummins mention this on their website? A guy at the Toyota dealer claimed Toyota is planning (pending the succes of the Titan) a cummins in the tacoma and 4runner in 2018...I couldnt find anything on the interweb though....
everyone talks about what this kind of swap costs... it can cost as much as you want or cost is directly connected to your skill set/tools/time... I think I could do it for zero cash out of pocket... might even make $$ if I purchased it in a bread van I could sell/scrap after
BUT have you ever driven a vehicle with a 4bt? it's 2/3rds of a 6bt most of them out there were made as replacement engines in v8 chevy equipped bread vans and were direct bolt ups to the turbo 350 & 400 auto trans that were already in the 30 series step vans... I've bought sold and traded for and out of several over the years... they sucked so bad I'd try to get someone else to drive them wherever I wanted one to end up... SLOW LOUD & not smooth I guess they had enough power to pull around an aluminum box full of wonder bread... lasted longer and got 2x the MPG of the gm 350 v8 they replaced... but....
i Have a 6bt 12v turbo in a 35ft pusher motorhome that can cruise @ 95mph and get 12mpg doing it... that i'm pretty impressed with, but that is a 6bt
BUT can you make the 4bt work with the trans in a 98 100 series? that and the factory dash... the rest is all just parts that any ok skilled metal fab person can do... I'm just not sure what you have when done? what I know you have is something only you (if you built it) can keep running and would put up with...
If i was in some remote part of the world and had a dead 100 and a running 4bt and a source for fuel that would burn in a 4bt and it was my only option... I think I could do the transplant with little more than a rat tail file, time and some scrap iron...
as long as I have access to gasoline I think I'll keep my 100 eating it's fuel of choice
Here is a full recap of the guy who just finished his 80
Update on the Cummins conversion-
After I was able to get the vehicle in my hands my had everything in place. The budget was broken down for the remaining steps to include a reasonable lift, Paint, tires, wheels and possibly a new Slee rear bumper. In addition I added some slush for a front axle service and new brakes on all 4 corners. I needed more slush..
Here is a recap of my experience and overall ranking of each respective resource that was used. While nothing is perfect in expectation nor result I will give this conversion an overall 8 of 10. Mostly because of my ignorance associated with this kind of project. I got lucky in the outsourcing of many of the jobs and also had some bad luck as well.
First the decision to install a diesel took me one of 2 routes. A domestic sourced diesel or a Toyota diesel. While both options have their attractive qualities and I am certain that a debate exists over what is ultimately the best solution. No solution is without it faults and after a long deliberation and discussion with several individuals who have owned both types lead me to choose the Cummins conversion. The benefits were many and the reputation of an industrial engine in an industrial chassis was a very attractive option.
I researched multiple companies that offered a diesel conversion service. After a lengthy interview process of several mechanics literally from New England to San Antonio to the Pacific Northwest. After having a conversation with the guys from Diesel brothers in Utah, they referred me to the team in Kalispell Montana. Diesel Conversion Specialists, became the choice for my conversion based on their expertise in Cummins conversions but maybe because they would always answer the phone. Every preemptive question was answered and the expectations were set for a 5-6 month conversion. (Obtaining the kit from Duiser added a couple of months to the overall completion-Credit to Duiser, He was fundamental in providing support and product. His help was much appreciated) I would like to imagine him having a ready supply of parts on a shelf but I imagine demand doesn't support the idea. All the same his quality is second to none.
Once the engine was converted and I made the 1100 mile drive back to Denver, i couldn't be more happy. The vehicle ran well and had plenty of power. Fuel economy improved quite a bit and overall the job was done with a high level of attention to detail. This portion of the project gave me a false sense of security as it was completed in time and very close to budget. I figured the rest would be a cake walk...
The next step was going to be suspension. I needed a small lift, more so I needed a spring to support the additional weight. While not a massive increase in pounds 300 was enough to start sagging the 12-13 year old OME 2.5 inch heavies. As you can see the ARB bumper and 12k pound winch add a few LBS. I started to deliberate based on my questioning of several members of the Forum on how and what would work best. After detailed research and speaking to one of the foremost experts on Landcruisers I chose to use Slee to upgrade the suspension and provide me the strength but equally as important the drive ability of a stock LC! We opted for the 6# kit with Comp springs on the front and 4 inch springs on the rear. The kit provided the proper geometry and added security of the Slee Control arms. Tis was certainly not the only option nor the cheapest option. I felt it was worth breaking the budget to get this right. Lets also not forget , Having Slee in your backyard and not using them is kind of a shame ; )
Once the suspension was complete, we needed to work out a couple of small bugs. Having your install mechanic in Montana and the vehicle in Denver does not make for an easy solution. The boys at DCS made it simple! Using a shop in the local area we were able to get the small electrical repairs made with little to no effort. Wile I was in the shop i ordered Tom woods double cardans fro the front and rear shafts. i figured after a quarter million miles it would be a good time to have those replaced.. What a difference they made. The vehicle shifted as smooth as it did when new. The driveline had zero vibrations and the overall feel was nearing perfection. Mechanically we were doing great!
Now for the paint... I budgeted 5k thinking that should be more than enough. It wasnt... 3 k over budget...Dont tell the wife. New fiberglass, new black plastics, new grill, new logos and emblems, new mirrors and 11 weeks later we were done.
I went with Toyo tires and chrome wheels. While I thought i git a stellar deal on EBay. Finding the fifth wheel proved to be difficult and costly. Brakes were provided by the local Brakes plus great guys..! New discs,calipers,pads ect.. Went through and re tubed all the brake lines while we were at it.
Front axle service Complete...OUCH! rear axle service not too bad. Full fluid flush and Finally.... We were scheduled to put on the new Slee rear bumper.
It was 11 months to the day from start to finish. While this project is never truly complete (I have plans for new skin on the seats) It is done and being enjoyed thoroughly. I spent this weekend in sub 0 temperatures 200 miles from home and about 100 miles from the nearest mechanic running the rig through its paces. I awoke at 7:30 on Saturday and the temperature was a brisk -9 degrees. The Landcruiser (affectionately renamed the YETI by my boys) Turned over coughed a plume of smoke and started without fail. Running around the mountains in a foot of fresh unmolested snow, through rivers and fields the rig proved to be a blast! One complaint- It needed a radiator block to heat up to operating temperatures. Minor inconvenience.
That being said the cost of this project was over budget by several thousand dollars. I full expected to have this complete at under 30k. 35k tops. I now own a very capable vehicle that certainly turns heads that will also serve as home, camper and coffin if my wife ever finds out.
If you are interested in such a conversion, i would be happy to provide you with the steps to avoid the cost overruns that i experienced. If you are a competent wrench turner and have time, you could do the majority of the work I outsourced ( I would recommend having the guys at DCS do the engine swap regardless of your competence,Its worth the brain damage.) and easily finish this project for under 30k.
New Re manufactured Cummins 6BT Complete new rebuild. from the Pan to the turbo is all new parts. 12k Plus labor and Cummins conversion kit***
New exhaust 1000
New suspension complete package sans Heavy Comp springs 5k installed
New radiator Toyota OEM 300
New brakes-1100
New rear bumper installed 3400
New tires and wheels 2100
New axles 1300
New shafts 650
Paint and body including all new fenders, belt moldings, mirrors and grill-8500
*** Labor and kit can be discussed with the team at DCS or you can privately message me.
Regardless of any other factor, if I had the money I'd do a diesel swap in a heartbeat SOLELY for that beautiful diesel clack-clack-clak sound. I don't miss the 50mpg I was getting in my diesel Golf, but boy oh boy do I miss that sound!
As somebody that had a 4BT in their 80, here is the problem. The 4BT is a tall motor, I think you are going to have problems fitting it in without going SAS and a lift on a Hundy. You had to do a 6” lift on the 80 to fit the 4BT in there and clear the axle, suspension and steering components. With an IFS set up, it may not be doable:meh: The 6B may be a shorter engine as I don't think it required the yuge lift the 4B requires.
Plus, the mileage aint that good. Better than the 1FZ, but not great, plus that motor is a little small for a heavier truck like the 100. Best I got with the 4BTA in the 80 was barely 20, usually 18-19 MPG was the norm.
If I was going to spend the coin for a diesel, blow the wad and get 100 to a quasi-factory set up and drop in a 1HDTFE and an H55F:hmm:
well damn... there is my million dollar idea for the year an interactive iphone app that would link with your onboard port and interact with your sound system to provide real time diesel sound through your stereo in a gas engine vehicle.... c csm 2016
I'll be your first customer
