Cruiser won't start
Central Florida
My 80 won't start, the battery has plety of juice, my battery terminals are clean. When i turn the key it does nothing. Had to have it towed 30plus miles from work to home. Any ideas.... i've been studying and searching the bad starter threads, to see what i can find.
Oh.... great and knowledgable cruiser dudes help a guy out here...
hit the starter with a hammer and try again?
Chasing this same demon currently (only towed 2 miles from grocery store to driveway though). New fusible links and alternator brushes arriving from dealer tomorrow. I'll let you know if either/neither fixes me up.
Search for "intermittent starter" or "no start" or something similar. There are a ton of good threads about non starting cruisers.
Mine does the same thing occasionally. make sure the terminals are not only clean but really tight as well.
Do you hear a click from the solenoid?
Do the dash lights stay on when you crank?
When was the last time you replaced your starter contacts?
You should also hear a smaller click from the starter relay, you may have to find it & feel for the click. If you don't get that, there is a problem on the low current side of the starting circuit: Neutral safety switch, Ignition switch, Starter relay, etc.
Does your LC have an alarm installed, even if it is "disabled"? There is a lot more to starting the vehicle than just the battery, starter & cables.
Do you hear a click from the solenoid? Yes i hear a click
Do the dash lights stay on when you crank? Yes lights come on..
When was the last time you replaced your starter contacts? Never replaced the contacts
hit the starter with a hammer and try again? I bang the heck out of it with a tire iron
Mine does this from time to time. I have found that the gear selector has to be just right or it wont start. In mine if the "P" light is not on it wont start. I just bump it forward a bit, the light comes on and fires right up.
