Build Cruiser Patch 2003 LX470 Build Thread
cruiserpatch
Supporting Vendor
Atlanta, Georgia
Website
www.cruiserpatch.com
That's right we got another one.
Figured I should break into the mid-late 100 series model years to be able to develop products for them and test fitment etc.
This one will primarily serve as the wife's DD but will also be a sleeper build.
So far I've baselined it (see list) but will be upgrading things as time allows.
184,000 miles with some rust, a terrible paint job (looks good from 10 feet), horrible body work and a whole host of other problems. Perfect. Paid $5,800 for it which was too much in hindsight but how would I have known the AC compressor would fall off? What a POS...
Maintenance and repairs:
  • Brass heater tees
  • Condenser replaced & several AC lines
  • AC compressor was not tightened to engine block. Fixed that
  • Replaced leaky aftermarket exhaust parts & muffler w/ used OEM
  • Replaced steering rack with 44250-60100 LC rack and Cruiser Patch claw washers
  • Replaced motor mounts
  • Replaced outer tie rod ends
  • Replaced fuse box lid gasket
  • Replaced idler pulley with NSK
  • Replaced tensioner pulley bearing
  • Replaced front wiper blades with OEM
  • Replaced cabin air filters
  • Replaced engine air filter
Mods:
Removed and sold wheels and tires immediately. +$650
Sold roof basket +$100
Began body repair work. What a mess....
The previous owner or whoever he hired to flip this thing did some of the worst body work I've seen- ever.
Not a good thing coming from me. I use a sledge hammer to repair my truck hahaha
Pretty sure that wire is structural
Oh look another one! Why use fasteners when you can just tac everything in place and not paint it?
wtf...and it didn't get any better
Structural zip-tie. That broken bumper would stop a direct impact. I'm sure of it
Pretty quickly I realized how bad the situation was. It would need a lot more than just a touch-up.
I could tell the frame rail was bent just by looking at it. The x-member had taken an impact crushing the condenser but somehow not the radiator? The trans cooler was bent but not leaking. I've left it alone.
The RH #1 body mount was under a lot of strain from the bend.
I used a bottle jack to push the frame rails back to factory width then cut out the bent section and welded some 3/16" square tube in place of the crossmember. Not perfect but so much better. Relieved tension on the body mount and got things back where they should be.
I've had a few parts trucks lying around which was part of my logic for buying this one. I knew I could source things to fix it up but didn't expect I would have to go this deep. No matter. Onward.
A few cans of black paint later...no one would know the valance was ever green.
See if this fits...ah! Yes perfect fit. Now to make a custom wire harness for it...and add a hole for the fluid level sensor.
And throw on a 1" body lift...
Nice job saving this one. Congrats to Charissa! I hope she loves it.
Will we be seeing it in TN this month?
I bought it for her and initially she didn't like.
Then I cleaned it up a bit and she's all over it. I got excited and thought I might have another wheeling rig project for a second there haha
TBD if it will make the trip to COTR or not. The front diff was seized when I bought it so it's been in RWD since. Probably won't have time to get the ARBs and 4.30s in before then...my goal was to have it ready for next event season (thinking GSMTR as the debut).
The carpet was in need of some love as they all are.
Has a little rust here and there so I've been cleaning it up as I go.
Deleted the DVD player
Nice work, Patch. I will be following along with hopes that I get a clean, stock 100 for the missus.
Love the Vidal front, nice and lightweight, with lots of hole patterns to mount a radio, lights, winch etc.
I did make a Badlands 12k winch relocation kit when I did this bumper with a 3d printed box.
I feel like our trucks are similarly built lol
Valve cover gasket and spark plugs today. Original VCGs and plugs also seemed pretty old.
4 of 8 plugs were only finger tight. Feels good to prevent catastrophes
Old plugs were DENSO SK20R11 which is what they got replaced with. Old plugs said "assembled in USA with Japanese parts." New plugs said "assembled in USA with foreign materials." Probably all the same but who knows?
RH & LH covers were totally different where cleanliness is concerned...when I did this on my 1999 both covers looked like the LH (dirty).
This truck may be a total beater rust bucket but at least the motor was taken care of along the way.
185,093 miles
Buttoned back up with new hardware. Might replace the PCV valve might not. Hoses are definitely a bit crusty.
VCG kit
PCV valve kit
Also pulled the running boards off in preparation for a visit to @Chippiepooh
(water accumulates in the RH rocker panel. the pinch welds are a bit rusty in spots and therefore blocked/clogged)
Had been leaving an oil spot in the driveway which prompted the VCG job. Also smelled oil burning on the exhaust at times. Unpleasant
The oil leaks seem to have kept the front cross member nice and solid though!
I attribute oil leaks to the pristine condition of the underside on my 85 diesel Benz. Not a spec of rust under there after 40 years and 360k miles.
Unfortunately this one was not spared. Chipping it for 37s right now and have been forced into some rust repair “while in there”
Turns out it’s a good thing I’m cutting holes in the body 😂
“honey, this IS maintenance”
Drilled out all the pinch welds on the inner fender and tucked the engine bay by about 1" all around.
Also cut out a large rusty section which happened to be the area of rocker that would've needed to go anyway.
On my 1999 I used rivets to fasten the sections of engine bay back together but I decided to weld this one. Much more solid
A little more hammer work and it'll be G2G on the driver's side.
Did you use a BL?
Just a 1" but yes. Used 1" on my truck and this one. Sweet spot IMO. Still a lot of work but not nearly as much required.
2" might save you from having to cut into the engine bay but the rocker would still need to be chopped and capped if the caster is setup correctly
Ignore the toe but here are my current alignment numbers for this 2003 LX. This is with the SPC UBJ in the "B" position so theoretically there's more caster to be achieved. (Sheet is for 25455 but the arms are the new 35455)
EDIT:
So besides the pinch welds, do you also need a body lift in order to fit 37s?
BL is not needed to fit 37s but you'll have to cut a lot more into the firewall, engine bay, and body overall to make them fit.
.5" BL gets you well within easy install for tall 35s or 36s with some mods to the pinch welds.
1" BL gets you closer for 37s but still have to chop about 2-2.5" into the rocker and tub the inner fenders/engine bay. Also have to cut the outer fender which I haven't done yet.
Relocation of the washer bottle is also necessary to fit anything bigger than a 35
*this is all assuming you're not limiting up travel in the front. by doing so you're essentially limiting an already very limited suspension to even less travel- not worth it for larger tires. better to keep all the travel on smaller tires than lose an inch (about 1/7th of total wheel travel)
