cruiserpatch
Supporting Vendor
- Joined
- Nov 24, 2020
- Threads
- 140
- Messages
- 1,422
- Location
- Atlanta, Georgia
- Website
- www.cruiserpatch.com
That's right we got another one.
Figured I should break into the mid-late 100 series model years to be able to develop products for them and test fitment etc.
This one will primarily serve as the wife's DD but will also be a sleeper build.
So far I've baselined it (see list) but will be upgrading things as time allows.
184,000 miles with some rust, a terrible paint job (looks good from 10 feet), horrible body work and a whole host of other problems. Perfect. Paid $5,800 for it which was too much in hindsight but how would I have known the AC compressor would fall off? What a POS...
Maintenance and repairs:
Removed and sold wheels and tires immediately. +$650
Sold roof basket +$100
Began body repair work. What a mess....
- Brass heater tees
- Condenser replaced & several AC lines
- AC compressor was not tightened to engine block. Fixed that
- Replaced leaky aftermarket exhaust parts & muffler w/ used OEM
- Replaced steering rack with 44250-60100 LC rack and Cruiser Patch claw washers
- Replaced motor mounts
- Replaced outer tie rod ends
- Replaced fuse box lid gasket
- Replaced idler pulley with NSK
- Replaced tensioner pulley bearing
- Replaced front wiper blades with OEM
- Replaced cabin air filters
- Replaced engine air filter
- Alpine siege HVAC breakaway control board (Nav-delete)
- Prius rear wiper arm
- DVD player deleted (installed dome light over headliner hole)
- LX to LC corner lens (turn signal retrofit)
- 1" body lift (flat-out offroad) - recommend using larger diameter washers than provided
- SPC 35455 upper control arms with Cruiser Patch lockout plates
- Cruiser Patch washer fluid tank relocation kit
- Cruiser Patch alignment lockout plates (eccentric cam delete)
- Cruiser Patch bolt-on LCA reinforcement bracket
- Cruiser Patch steering rack claw washer upgrade
- Added AGM battery
- Added HKB voltage booster
- Cruiser Patch seat back net frames
- Cruiser Patch HVAC drain extension kit installed
