- Thread starter
- #161
The last time I had the Crockpot off road in a situation where the suspension was twisted up I discovered that the rear tires had an affinity for sheet metal...specifically the rear quarter panels. In the pic you can see the wedge shaped gap between the flare and the body where the tire basically folded back the rear section of quarter panel. I suppose I was lucky that I didn't cut the tire...especially so because I was really out in the middle of nowhere when it happened. Both sides were equally mashed.
Yesterday I decided to do a tad more fender trimming. As much as it pains my soul to take away more of Mr. T's precious vintage sheetmetal, it had to be done. Sure, I could have lengthened the bump stops but the rig struggles to flex as it is sitting on 4" lift springs. It needs all the help it can get. Here are a few neighborhood ditch flex poser pics taken with the flares removed and the new cuts made:
No more fender bender (which is good). I made some cuts to the inner part of the flares to match the sheetmetal cuts and re-drilled and re-installed them.
One last thing...notice that in the pics that the rig has a front wheel up. I'm disappointed in the lack of droop on the front axle. I'm not sure if my shocks are too short, limiting the droop or if the stiff, highly arched 4 inch springs are the culprit. When I ordered the shocks I thought I had measured correctly, but now I'm second guessing myself. I think I will take the shocks back off and do the flex test again without them to see if it makes a difference.
R
