coil spacer question
Middle Tennessee
looking at getting the man a fre 30mm coil spacers to gain a bit more clearance. will i need to get an alignment after these at all?
is it worth the trouble. for 70 for all four and an inch lift sounds good to me
I run them in the front of my rig , There pretty good bang for buck especially if you have lift issues with the vehicle licence and need to lower it easily for vehicle licence inspection etc
I have them front & back on top of 850/860 OME. I have had no issues whatsoever. I had them on for about 6 mo. before the lift, and had no alignment issues. I'd say go for it. The one inch made more of a difference than I thought they would when I first installed them.
I'm considering doing the same thing. When you say the spacers made more of a difference than you expected....what aspect are you referring to? height, handling, ride....?
lets see some pics
I love my MetalTech spacers up front, I also like that they lower the whole bump stop assembly
Yep.
I haven't added anything to the rear as I'm waiting to see how a winch will effect the front before making a desicion. (J/L's all around + 2" MT Spacer setup in the front)
I used them on my LX450 and I think it rides much better than stock due to the fact that you do not hit the bump stops for another inch. Definately worth the time and money to install!
ok im about to order em. i know it took me long enough!
I've got 2" Metal Tech's up front and 1.5" aluminum Slee's out back :cool:
Didn't notice any difference in alignment, but it just barely brought me over stock height since my old springs are saggy and I'm running a lot of extra weight (loaded roof rack, winch, dual swing outs, etc.)
Are the manafre spacers just a slip the springs out, install spacer, replace spring type thing? Or are there potentially rusty bolts you will encounter?
You'll have to disconnect your shock bolts to drop the axle enough to install spacers. Good Ideal to give your rear brake line some extra slack if you have not already.
Yeah, figured I'd clean everything up while I'm all up in there. I'm gonna do the 1" all around. That way when I upgrade to my ome lift I can still use these
I just ordered a set of these for the front stock springs. Im just hoping to level the stance a little and make some more room for some new tires 285/75 r16. I know that this tire option will work with stock suspension but a little better clearance and approach angle wont hurt.
To be honest, the only reason i bought these today is that I am obsessed! I cant keep my hands off of my 80. 50 bucks is a cheap upgrade and a good excuse to get back under the truck.
30mm MAF spacers
My 30mm spacers showed up from Man-a-Fre on Friday afternoon. Install was easy. It took me 45 minutes to an hour to do this job on my own. The truck looks better and even rides better. I dont know if this is the placebo effect or what but it seems more stable in corners (the wife even mentioned it). another little bonous is that the anoying shock squeak on the front drivers side is gone. Im not holding my breath on this lasting but its gone for now!
I think the best part about doing this job yourself is the knowledge you gain about the suspension limits. I was blown away the first time I lifted the truck on 6ton jack stands fully extended. The wheels were still on the ground when i dropped the axel jack away!!!
Im going to add a picture a little later from the same location as my original to show the difference in stance.
Until then...
30mm MAF spacers on stock 95FZJ
these are pics of my stock 95FZJ80 before and after the 30mm coil spacers from MAF were instaled. I can't tell a big difference in the pictures but you can tell they leveled it out when you are up close and personal.
On the front, they change the caster by about 1.25 degrees.
My '93 is completely stock and probably sagging a bit after 19 years. Will this 1.25 degree caster change effect anything adversely or will it pretty much take it back to 1993 stance levels and caster angle? I don't want to have to get into caster correction issues...yet. I'm assuming 30mm spring spacers on a completely stock truck will not need caster correction bushings? I'm new to the world of lifting 80s, as you may have noticed. :p
Thanks,
Mark
