- Joined
- Jul 6, 2003
- Threads
- 43
- Messages
- 133
So i'm about to dive head first into a clutch job... oh yeah, my first clutch job. I have a lot of guys that seem to have "ideas" about how to do it, but none of them will be there when it comes crunch time, nor have they ever worked on an FJ40, which we have all come to learn aren't like "all other vehicles". So I'm left to rely on my intuition, my Haynes manual, and you wonderful people here on the forum.
So far I have the tranny hump out (along with everything else in the tub for a herculiner job) the skid plate removed, the drive shafts disconnected from the transfer case, the bottom access panel of the bell housing off. So basically it's time to remove bolts and actually move the tranny.
Somethings I'm concerned about: at first I planned to unbolt the bell housing and slide everything back to change the clutch, but I found today that not only will that be prohibited by the fact that the housing wraps around behind the flywheel making it imposible to pull straight back, but also the bell housing acts as the rear motor mounts as well. So plan b. is to take the tranny off the bellhousing.
How far will I have to take the tranny back to clear the spline shaft? I'm worried that with the trans case on i may not have enough room and I may get stuck hitting the cuttout of the tub.
Another thought is, the only reason i would need to get the tranny completely out is to access the pilot bearing through the figure 8 hole of the bellhousing which the tranny sits in. So do I have to replace that bearing? If I don't really have to replace that bearing I can just pull the tranny back a few inches to change the clutch.
The rear main seal. I've read that this should be replaced during a clutch job. What does it entail? Will I need to drain the oil and remove the oil pan? Or is it simply pulling the old one out and putting the new one in? Again, is this essential?
I haven't decided how to move the tranny... any ideas? I'm thinking about rigging a pipe through the doors and hoisting it with a come-a-long. The pipe will be able to roll fore and aft so i can slide the tranny back. I'm also considering getting a tranny jack, but that would be a pain in the ass cause the closest place is a ways from here, and my wheels are out of comission so I'd have make a bunch of arrangements to rent a jack, or cherry picker.
Anyone have some good pics of their tranny job? If so please email me at mikemcdonald@hatcher.ws
If anyone has a lot of expertiese it would be cool to chat with you, so if you have time and want to, look me up on aol instant messanger, skiakhokie
Thanks guys,
Mike
Oh yeah, I don't know what kind of difference it might make, but I'm replacing a stock clutch with a centerforce from Man-a-fre.
Thanks guys,
Mike
