Cleaning Steering knuckles
"the whale's vagina", CA
Looking for better ways to clean steering knuckles when doing a front axle rebuild. I have always just done the old hard way of a scraper then wire brush but that is very labor intensive and time consuming. Wondering what others have used as far as chemicals to strip the thick amounts of grime off knuckles? I know a hot tank is probably the best but don't have that. I was considering trying aircraft paint remover / stripper?
Thanks,
Noah
Engine cleaner soak followed by pressure washer. We do it first, to reduce the mess coming apart, then a follow up treatment when apart.
$100 parts washer from Harbor Freight and 10 gallons of diesel. Worked great.
As discussed the other day, see if you can find a steam cleaner in your area.
And I'd try engine degreaser (or kerosene, which is pretty much the same thing) or TSP in hot water long before I'd even think about paint stripper.
for clarity purposes guys I am talking about cleaning them OFF of the car, when doing a rebuild
my buddy matt camp mentioned that he douses them in degreaser and then wets rags with degreaser and wraps the parts with the wet towels and then wraps everything with plastic wrap, lets it sit overnight, I am going to try this and then hit it with my power washer.
Diesel cleans just about everything..... including the bath tub AND the dog!
Lye (sodium hydroxide) or trisodium phosphate in water is cheap and makes short work of it. Not so good on aluminum and don’t get it on your skin or in your eyes.
good info thx pinhead, I have a bunch of that on hand, any advice on the mixture % that works best?
I used PSC1000 from Tractor Supply. Its a really nice solvent and doesn't stink everything up like diesel. Dries clean with no residue to speak of. I would soak parts where it is caked and use a few different wire and nylon brushes to get all the nooks and crannies. Everything came out great.
