Happened to go out to my truck this afternoon to drop some stuff off, figured I'd pop the hood to see how the heater was doing on the coldest day of the year to date (high of -26C, feels like -38), and I was disappointed to find the engine and all heater hoses were stone cold. Went and grabbed a co-worker's extension cord with a light in it and confirmed there was no power to the plug-in. Alerted property services, and went to move the truck around to another plug in that was working for the last hour of the day.
Truck did not like this, started rough, slow to respond to throttle inputs (doesn't want to bring the revs up when given gas, once it catches it's fine again), wanted to stall. Got it moved and plugged in though. Started it at the end of the day, took a lot of cranking and some gas pedal, got it running and set the hand throttle around 1300rpm for about a minute, and started to slowly drive. Even after the temp needle had moved off cold, the truck idles real low and wants to stall. I ended up having to slip in in neutral and keep the revs up a bit at stoplights to keep it from stalling. Did this for about 10min of driving, then smartened up.
I'm ordering some new glow plugs tonight to see if that helps. Does this sound more like a glow plug issue, or a fuel gelling issue? This is the same way the truck was running when I had problems at Christmas time, no fun messing with stuff when it's that cold out.
