Yes the supplied barb will thread right into that drain port i put a bit of teflon tape on the threads just in case. Just remember you will lose alot of coolant when you take the plug out. With me i took the little one out and then some coolant came out. maybe half a liter or so and when i removed the big sleeve it was threaded into i lost alot more... about two regular coolant jugs were needed to refill.
I have not run my output hose from the zerostart to the other side of the engine yet. I will be going to lordco afterwork to pick up what i need and will most likely attempt it tomorrow night.
You can access the drain plug from the top using a socket. Just have to get the right length extension to allow room for the ratchet because you will be amidst all the throttle cables and such. You probably wont have a problem like i said, i had the steering rod that was in my way, this wouldnt be a problem for you.
