This site may earn a commission from merchant affiliate links, including eBay, Amazon, Skimlinks, and others.
Mace said:
Brass Barb Fittings - PlumbingSupply.com
also, the local hose place here in town has fairly large brass bulkhead fittings, that may be your best bet.
For which issue are you suggesting this link for mace? The firewall/ heater hose, or the vent lines/ roll over valves?
Funds for TLCA RE DISTRIBUTED to BRC, KE7VAT
76 FJ40 "Matti" short for Matilda, "powerful Battler".
GET OFF YOUR ASS and DO SOMETHING! Join/ support and volunteer for clubs and organizations that actually fight to keep trails OPEN!
rock scientist..
Staff member
s-Moderator
Moderator
either actually. not the roll over valves, but general plumbing stuff..
"Hallucinations are bad enough. But after awhile you learn to cope with things like seeing your dead grandmother crawling up your leg with a knife in her teeth. Most acid fanciers can handle this sort of thing. But nobody can handle that other trip-the possibility that any freak with $1.98 can walk into the Circus-Circus and suddenly appear in the sky over downtown Las Vegas twelve times the size of God, howling anything that comes into his head. No, this is not a good town for psychedelic drugs."
I was hoping there was an in line check valve on there I wasn't seeing. All I can find at summit are the bulk head valves.
rock scientist..
Staff member
s-Moderator
Moderator
LOL...YES!
Ive been looking for a decent option for the fuel vent. I had actually ordered the in line vent valve from fuel safe...
Im just thinking that for additional protection in the event of a FLOP that an actual roll over valve would be good on the END of the line. Seems that 3/8 in roll over valve would be okay??? Not too expensive either.
Got any suggestions for diff breathers valves to stick on the ends of those???
Kinda like the ones from the factory?
rock scientist..
Staff member
s-Moderator
Moderator
rock scientist..
Staff member
s-Moderator
Moderator
No valve in the axle breather..
If you manage to pour most of your axle fluid out, you are doing something wrong... Seriously wrong..
Cool.
The valve I was thinking, was to keep water from going into the diff. I thought that was how that little deal worked from the factory.
rock scientist..
Staff member
s-Moderator
Moderator
Cool.
That's why you raised the tubing to a high point in the chassi..
Cool.
You might want to talk to Spressomon, I think he tracked his rear axle seal problems to the factory vent valve clogging up. If I know him he came up with a spiffy solution to the problem.
Just put a cheap or used fuel filter on the end. Keeps crap out and lets the diffs breath. Mine is just zip tied to the fire wall rib on the PS up as high as I can get; no need for anything fancy.
74 FJ40 - 78 2F desmogged/THC non-USA carb/non-USA dizzy w/ Pertonix/sag PS/OBA/SM420/3spd/SOA/35's/Longs/Hi-steer/ARB R
Elk Grove, CA
glutton
Moderator
Yes...knocking on wood and crossing fingers it appears I've found the solution to my diff fluid blow by at axle ends, pinion nose and breather! So far after going to 1/2" ID vent hose (clear BTW so I can see what's going on...another CIR sourced part) and 1/4NPTM barb fitting on the axle housing and running straight up to the side of the rear hatch no more pressure build up.
I originally ran the rear diff breather line all the way to the firewall. But I discovered plenty of diff lube sitting in the long horizontal run of 1/4" ID line...that was interfering with easy diff venting.
Used plastic fuel filters from O'Reilly's...I think they were about $7. As above ^^^ any fuel filter will do.
Sam clued me onto this...its amazing how much sloshing the diff fluid does (and subsequent diff fluid migration into the breather hose/line!) on rougher and faster trail sections...and how much real pressure develops in the diff housing assembly.
1999 100-Series...
spressoWAGON ROTM
2009 Kimberley Kamper Sports RV: Sold; 2006 Adventure Trailer Horizon: Sold;
TrailTailor Trailer: Sold. 2014 Escape 15A fiberglass trailer: Current project
No espresso = Depresso
BlueRibbon Coalition life member
So progress is obviously been pretty slow lately. Im currently waiting for brass elbows to come in for the heater line from Mcmaster carr.
Did a bit of wiring clean up, gotta pull some more wire, looking to find some roll cage speakers that I like and or can make...Just kinda taking my time right now I guess as I have ALL WINTER to do this now...
Here's a couple shots of the dash gauges and brake lines.
Looking good love the gauges ...
... There's a lot of folks in this forum with good info to share. and a lot with very little to base their very strong opinions on...
82 FJ60 5.3, 4l60E, SOA, 35 Procomp M/T,456's, lockrights, ARB bull & side bars and a 12K Warn
82BJ42 ARB bull bar, 24volt 8274, 33's ,3b,H55, FJ60 P/S and a dream
Aaaaah..... Thanks amigo!
I don't usually like non-OEM gauges, but those are really clean looking.
Are you sure the brake lines aren't too exposed to rock damage running under the springs like that? Mine are on top.
Hey have you put bolts in your yokes??? mine came drilled too small had to buy a bit to drill em out
No. I do have to do that still, and mine too are too small for the cruiser shaft bolts. I've been putting that off for no particular reason.
Maybe. I ran em the same way on my 62 and didn't have any issues with it. However, that's not to say I couldn't.
